Engine Colour
Steve
Platinum
I spent a wonderful afternoon taking the manifold off the 'B' today. I had suspected this before, but having full access to the manifold side of the engine which is now cleaned and degreased, I can confirm, that it is painted red, not the black that it is supposed to be. It's a definite, brick red. Wierd. Has anyone else seen this before? It's a low-mileage 1980 MGB, ad the engine is the original one fitted to the car, according to the Heritage Certificate........any ideas?
Bret
Same here – my 78B’s engine that has “supposedly never been rebuilt”, has about 120K on it and like your's is painted red (brick?) too. Not 100% sure about the miles, as the Speedo didn’t work when I first got the car.
This has always perplexed me, because I always understood & read that the block was changed to black on later Rubber Bumper Bs.
Mickey Richaud
Not sure where I read it - maybe Clausager's book, Original MGB, but one source said that even though the change was made to black with the 18V motors, some of the later ones were painted differently. There was a picture of one that was multi-colored - kinda splotchy like camouflage - black and dark red.
Mickey
Bret
Just pulled out Jonathan Edward's MGB and MGC book.
According to the information in this book the switch to Black from red started from Mid-71. (pg: #40) New built engines were painted black, instead of red.
I'm Still confused! /ubbthreads/images/graemlins/tongue.gif
Steve
Steve
Platinum
To further confuse the issue.......there is evidence of yellow paint having been used, possibly as a marker or an indicator of, well, something. Clausager's book definitely states that all 18V engines were painted black, but there is no evidence of this having been done on mine. The "brick red" I mentioned is probably more of a terra cotta I suppose, and has the look of primer.......could it be that the engine was primed but never painted, and that by May of 1980 when my car was built, the workers at Abingdon didn't care enough any more to do something about it? I will try to take a digital picture today and maybe post it if I can......maybe with a little help from my friends......Hey Basil! /ubbthreads/images/graemlins/grin.gif
Bret
[ QUOTE ]
Well that would explain it........hmmmmm, maybe it's time to get the rattle cans working since I have all the "junk" taken off it.
[/ QUOTE ]
/ubbthreads/images/graemlins/lol.gif Ahh, the old rebuild in a can trick.
FYI – If you haven’t already done so – you should change the gaskets of the engine's side panels (lifter access). These are notorious for leaking oil. That side of the engine gets excessively hot from the exhaust and even more so if you have a catalytic converter.
I changed mine when I had the manifold off of my 78B and my oil leakage is almost nil now.
/ubbthreads/images/graemlins/thumbsup.gif
D Engine Colour for a 74 Midget. Spridgets 8
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
