MTribe
Hey guys, I have this coming week to put a TR6 motor back together from a bare block, and after some searching here on the forum, still have some questions:
- Do you use any sealant on core plugs? If so, what's recommended?
- What types of sealants are recommended for which gaskets? Hylomar sounds good, but messy?
- The original oil gallery plugs (aka the set screws) are all in place and there was no leaking. I bought a set of new ones, but I wonder if it might just be better to leave the old ones in there?
- What types of lubricants should I use and where to avoid damage on start-up? I've read cam lube on cam, assembly lube on bearing surfaces and in oil pump, and engine oil everywhere else--sound about right?
Sorry if some of these are repeats--I found a lot of bits and pieces but nothing quite as definitive as I had hoped! I'm taking this week off work to finish the project and any advice would be very timely and perhaps save me some headache down the road! Thanks!
Steve
Steve
