A few weeks back I did a couple of pulls with the Courier on a rolling road setup. The fuel-air was was way off and in the limited time we had I succeeded in getting the mixture squared away to the extent that I gained about 25 ft/lbs of torque and 4 or 5 HP.
In any case I have arranged to have a significant amount of time--probably as much as I want--for next Saturday and would appreciate receiving advise on what I should do to "maximize the experience", both prior to and during the pulls.
Obviously I should get my carbs balanced and valves and timing set but what if anything else prior to the pulls? What about tire pressure? And what should I be playing with from pull to pull?
All help appreciated....
