Door Check - Color?
mjobrien
OK folks getting down to minor details - the door checks on the 100 were painted body color? There are two parts, the part that mounts to the pillar and the part that extends to the door.
One would assume they were all body color with the way these things got built.
Thanks in advance,
Michael
55 BN1
BN1
HEALEYJAG
Michael:
I will check my book when I get to the house...I Left mine non-Painted since this is a moving sliding part some of the painted surface will flake off..will let you know what the picture I have shows..
Pete
HEALEYJAG
Michael:
From the pictures in my restoration books they are NOT painted..
Pete
R TR4/4A Door check straps Triumph 7
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
KVH TR4/4A Door Check Straps Triumph 11
Michael Oritt Door check installation Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
M BN1 door check replacement Austin Healey 9
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 Door check strap Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
G 6 door check noise Triumph 13
K door check strap Spridgets 10
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
A Door check Lotus 4
S TR2/3/3A door check straps for tr3 Triumph 1
W Broke check strap on door Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
S TR4/4A TR4 Door Check Straps Triumph 4
This14u Spitfire Spit Door Check Triumph 3
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
6 door check strap Triumph 6
I TR6 Removing door check arm in TR6 Triumph 6
TRopic6 For Sale Midget MkIII (GAN 5) Handbook, Door switches, Wiper blades Spridgets Classified 0
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
J TR2/3/3A Looking for helpful hints for door hinge screw removal Triumph 17
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T Heater Door Spring Austin Healey 1
C Door Latch Mechanism Austin Healey 3
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 22
B Which is the correct door knob for a 59 bugeye? Spridgets 3
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T Original Door Pocket Spridgets 14
T Interior Door Panel and Top Rail Austin Healey 3
