G
Don't use "Metal Ready" prep for regular paint !!
I bought POR-15's Metal Ready to cover up some rust and read on the package you can use it for a prep for regular paint also........DON'T !!!!!!!!!
Their instructions tell you to rinse off with water after 10 or 15 minutes and then dry. What it doesn't tell you on the package is that it will flash rust durring and afterwards. Why would I want to use something that promotes rust after I spent 3 DAYS media blasting my top frame to remove rust ?!?!?!?!?!?!?
If you goto their site, it'll state that it may flash rust "but POR15 loves rust anyway"......and this is in the instructions for regular paint prep !!!! Shouldn't this be ON THE PACKAGE ?!?!?!?!?!?!?!?!? Why would I want flash rust under regular paint ?!?!?!?!?!?
So......apparently you can use it for regular paint.....as long as you use POR15 instead !!!!!!
Looks like they are more worried about selling more POR 15 and making you dependant on it than customer service or concern.
I also found out their "solevent" is just acetone. My local body supply guy said someone at the company (POR15)told him this.
"Use only POR15 solvent with POR15", "Metal Ready can be used as a prep for regular paint", "the check's in the mail".....etc........
It's obvious profit is their only concern.
Luckily I had some Ospho here and that saved the day.
Man I'm so mad !!!!!!!
