do improved-design fuel pump check valves exist?
eschneider
On a TR4 engine:
replaced pump. Moss unit supplied with poorly cut fuel line connections. Got another. ditto.
got another aftermarket pump. pressure was 8 lbs.
rebuilt original pump with rebuilt kit. Ran great for 2 miles, check valve came apart.
check valves on these things are pretty cheesy. anyone know of a better/uprated valve for the AC style pumps? Like to find the oil seal that nobody seems to be able to supply, too......
TR3driver
Great Pumpkin - R.I.P
Did the valve itself come apart, or did the entire valve just fall out of the body. The earlier pumps had a clamp to hold the valves in place, which could probably be retrofitted to the later 'staked' valve pumps.
Last I heard, TRF was supplying rebuild kits with the oil seal in them. I found an old brake seal in the junk bin that seemed to fit & work OK, but have no idea what it came from originally.
Re: do improved-design fuel pump check valves exis
Eric, have you tried NAPA for the pump or a kit? I've been surprised at their 'range' when it came to the old AC fuel pumps. Been a while but I was able to get a glass bowl replacement for one thru them for a client's car.
T
Tinster
Hey Doc-
A question:
Given how unreliable these mechanical fuel pumps seem
to be, are many folks installing electric pumps as backups?
After my recent nightmare with numerous failed mechanical
fuel pumps, I am not attempting to drive my car any real
distances until I have an electric pump installed as an
emergency backup. Switch over two shutoff valves and flip
a toggle switch and the electric pump takes over for the
failed mechanical pump.
Redundant? Yes of course. But I hate breaking down all the
time.
d /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
Brosky
Dale,
Bad idea. Repeat again, bad idea.
These pumps are NOT that unreliable. I'm on my second pump in 56,000 miles and I replaced the original only because I was painting the engine.
You had contaminated fuel and that filled up a pump with sand. Was that the pumps fault? Even after that you were flushing crap out of the tank.
eschneider
eschneider
No, I haven't - and that's a fine idea. Last pump I got from NAPA was an Airtex unit - good stuff.
I'm leaning more and more towards rebuilding original parts when I can, though. Ironically it's getting harder to do as more companies are discontinuing components in favor of assemblies.
The aftermarket unit I got was from Advance or AutoZone. <insert scolding here> I'll try an airtex unit, and talk to some specialist rebuilders.
Geo Hahn
I too have found the mechanical pumps to be fairly reliable and prefer them though I do carry an electric as a get-me-home spare. With a length of 5/16" hose on one end and 1/4" hose on the other, a spade connector for the hot side of the coil and an alligator clip for the ground it only takes a minute to hook it up.
I have never known a valve to fall apart so I would consider that an isolated incident. Have known them to fall out... might have been my fault. As Randall noted, some pumps have a little butterfly-shaped metal clamp that is held by a screw and secures the valves. I think that is a surer way of holding them in than peening or swaging or what have you.
TR3driver
eschneider said:
the valve came apart.....
That's strange. AFAIK, the valves in mine are the original 1959 valves (unless perhaps it's the 1956 pump that goes with the short block I was running); I've never changed them even though I've done the diaphragm numerous times. Maybe you got some defective replacements ? I hear there's a lot of that going around /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Ain't that th' truth. The "dealership mentality" is beginning to affect the supply side of the industry: "REPLACE the unit! Can't make any money on rebuilding it." The other situation is that most shops/techs don't know HOW to disassemble/rebuild sub-assemblies, or the things are built to self-destruct if "opened up" once.
It's a CONSPIRACY, I tell ya'!! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
steveg Improved Instrument Lighting Austin Healey 2
glemon Some cars are not meant to be improved upon Jaguar 4
Foura Stag An improved Stag!! Triumph 3
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
Sarastro Improved clutch on a 948? Spridgets 7
L New and improved with 95% less carburetor! Spridgets 20
Tabcon TR4/4A Building a new improved TR4. Triumph 8
A New Improved Dizzy Rotors Triumph 3
bighly Improved throttle linkage MG 1
P TR2/3/3A Looking for the improved TR3 steering box cover Triumph 32
drooartz The new, improved Tunebug 2007 plan Spridgets 6
bravenrace Improved Performance Plan - Opinions Please! Triumph 23
PeterK TR4/4A TR3-4A Improved Performance Cam from Moss Triumph 3
G Up-date on my new, improved engine..... Triumph 12
U Improved Throttle Linkage Bushings Austin Healey 0
pkmh Radio Knob Design For A 67 BJ8 Austin Healey 16
C Jaguar Design Director Ian Callum honored for his hard work Jaguar 0
T TR6 TR6 - alternative linkage design? Triumph 4
John_Mc Victory by Design/ Jaguar Triumph 5
C Lotus 15 history and design Lotus 0
RAC68 Paint & Design Suggestions Triumph 4
Trevor Jessie T-Shirt Design Spridgets 16
F Is the Austin Healey 3000 a midengine design? Austin Healey 12
pkmh Spinner Wrench - A New Color 'Twist' In Design Austin Healey 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
hymodyne help with design of roll bar Racing 9
jsfbond craddle design Triumph 0
Jim_Newman 3000 muffler design Austin Healey 1
N lotus stole my design Other Cars 3
Michael Oritt Garage Design Austin Healey 20
T fantastic new cam design !!!! Triumph 25
tony barnhill SSsnake Design Up-date MG 22
vping Front Suspension. What design changes did it have? MG 5
G Even Karmann couldn't grasp the wiper arm design Triumph 4
PeterK TR6 TR6 wind blocker design Triumph 32
Lin New Healey Marque Magazine Cover Design Austin Healey 9
T my header design info Triumph 10
78Z Victory by Design - Lotus - Dec 19th Lotus 3
Bret Stupid Design! Other Cars 35
aeronca65t DARPA Robo-Car Design Contest Other Cars 1
Mickey Richaud Design Ripoffs Other British Cars 3
G Victory By Design : Jaguar!! Jaguar 6
MGA Steve Could We Design a New Spridget? Spridgets 50
A MGB-GT MGB GT new design?? MG 12
M Rant #1...stupid design Jaguar 7
T SU Fuel Pump Mounting Austin Healey 5
FlyingCat Spitfire Fuel Sender Unit Triumph 2
G Twin HS4 Su's leaking fuel Spridgets 17
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
