Distributor Advance Setting
Jimmy74
Member
Hey guys:
Using a mallory electronic electronic distributor with a stock coil what would the proper spark advance be? Would it be 8 degrees before # 1 TDC timed with a strobe light at idle? Vacume advance connected or blocked while setting? Thanks.
R
RonMacPherson
Set full advance to no more than 30 degrees, at 3000 rpm. Then go back to see what the timing is at idle.
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
vette Distributor Advance Austin Healey 14
Joe Schlosser Distributor advance Spridgets 0
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
smaceng TR6 TR6 distributor advance and retard hook up Triumph 6
G TR6 1974 TR6 distributor advance spring specs Triumph 6
N Distributor advance query??? MG 4
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
I TR6 69 TR6 distributor/vacuum advance/retard help Triumph 4
healeynut A90 Atlantic Distributor Advance Curve? Other British Cars 0
I Vacuum advance unit for BN1 [Lucas DM2 distributor Austin Healey 2
N TR6 Need TR6 distributor advance weight spring Triumph 3
George Zeck Distributor / Vacuum Advance Q ....... Spridgets 11
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
