RAC68
I was told and would like verification that the front brake calipers on a BJ8 P2 are larger in overall size then those on a P1. Additionally, is it true that the wire wheel offset for a P2 is greater then that which is necessary for wires on a BT7?
I appreciate that the piston diameter of a P1 is greater then the piston diameter of a P2 but always though the overall caliper size were identical and the calipers could be interchanged. Also, I was under the opinion that the wire wheel offset needed for a BT7 was the same as a P1 and assumed a P1 was identical to a P2.
So, are my understandings and assumptions in error and if so, where?
Thanks,
Ray (64BJ8P1)
Thanks,
Ray (64BJ8P1)
