Differential bracket crack
jerrybny
Well I dropped the differential today to check out the brackets on my 73 TR6. well sure enough the right front bracket is cracket. That explains the clunking I have been hearing lately. According to TRF this crack can be welded and that will fix it. Has anyone had this problem and what did you do to repair it? thanks
G
tsi/trf/moss all sell kits you can use to weld over the affected area and reinforce the rest.
jerrybny
jerrybny
It looks like TRF has some reinforcement pieces that are used to box in the front bracket. Wondering if I get those welded in on both front brackets and then have the crack welded if this will be strong enough. I don't race so its not like I'm gonna be putting any unsual pressure on them. If fact I'm lucky if I put 2000 miles on the car a year.
The Moss kit looks like you have to cut a holes in the sheetmetal above the pins to install their kit. I perfer not to cut holes in my beloved TR6.
all thoughts, opinions are gladly welcome.
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
H Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
D TR2/3/3A rear shelf differential dome Triumph 9
TomMull TR2/3/3A Differential housing spreader Triumph 3
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
KVH TR4/4A Removing the Differential Triumph 7
KVH TR4/4A TR4 Differential Removal and Seal Replacement Triumph 4
P Bt7 differential Austin Healey 6
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
T TR4/4A Differential clatter-solid axle Triumph 4
KVH General TR Rear Differential Seal Triumph 7
M TR6 Pressure differential warning assembly PDWA valve Triumph 4
K TR6 Goodparts Nissan differential swap Triumph 3
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
F Differential Ratio Sunbeam (Rootes) 3
maxwedge5281 differential interchange for big healey Austin Healey 6
Steve P. Jensen-Healey positraction differential? Other British Cars 3
