Defective Part Notice:
T
Tinster
Moss Motors informed me they have taken all their TR fuel pumps off the shelves due to a product failure. Moss
has no replacement pumps available but will account credit
all pumps returned to them.
The defective pump puts out a pressure of 8 psi and is
reported to produce carb flooding as a result.
The fuel pump I installed in Crypty is the defective moss pump.
If you have one of these pumps or have installed one, send itback to Moss for a store credit. Better than nothing.
The fuel pump shown in TRF catalogue looks identical to the defective Moss unit. Perhaps the same supplier?
So the Crypt Car now has no functional fuel pump.
Platinum
Umm, Dale: is the spacing on the diaphragm screws the same on both?
...I would never advocate a swindle, but mebbe you could rebuild the old pump with just swapping the membrane... then bury the "new" pump inna sand. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
T
Tinster
DR- DPO had some "other" pump jerry rigged into
the car. I tossed that pump the same day it failed.
I did ask Moss if there was any method to reduce the
8 psi but they knew of none.
Yet another statement about the sad shape of replacement
parts we are forced to purchase for these cars.
I seem to have a gordon's knot here.
d.
Platinum
You've tried NAPA?
70herald
OK, this is progress of sorts.
Take a look at this: Facet electric fuel pump. It puts out the correct pressure and sufficient flow for the TR6.
I think you can get them at NAPA or other local dealers also. One advantage of the electric pump is that you can hook in a switch which makes it a tiny bit more difficult to steal.
https://www.pegasusautoracing.com/productdetails.asp?RecId=83
You can cover the hole in the engine block with a plate, the cover for a small bock chevy fits I think??
Platinum
Y took th' words right outta. And I think NAPA also sells that blanking plate.
dklawson
foxtrapper
Aftermarket fuel pumps having too high a pressure is a decades old problem. Be it Moss, TRF, Vicky Brit, etc.
This isn't a new problem.
70herald
2 reasons not to bother with the pressure regulator:
1. the regulator costs almost as much as the fuel pump so why bother????
2. that MOS fuel pump putting out high pressure is going to add extra wear on the camshaft/timing chain to develop that extra pressure.
Brosky
The plot thickens. If it can happen to anyone, it will be Dale.
TR3driver
Great Pumpkin - R.I.P
Another reason :
3) Adds another point of failure. Some regulators have been known to fail and spray fuel all over the place. There was even a recall a few years back of units made by Purolator and sold under several different names (including NAPA), but I can't find the link at the moment.
If you want to go electric, I heartily recommend the little Facet. No diaphragm to leak and I've never seen one fail. But note that they do come in different pressure ratings, and you want the lowest one (model 40105). Best source I know of is Aircraft Spruce https://www.aircraftspruce.com/catalog/eppages/facetpumps.php
TR3driver
Tinster said:
I did ask Moss if there was any method to reduce the 8 psi but they knew of none.
The pressure is set by a big spring. It would take some experimentation, but you should be able to reduce the pressure by trimming the spring down.
Unfortunately, you can't just cut the spring in half to cut the pressure in half.
I admire you for sticking in there with your "beloved"(?) automobile which continues to fail to procede! Have you considered a bicycle?! Ok, just kidding..... /bcforum/images/%%GRAEMLIN_URL%%/smile.gif That which doesn't kill you makes you stronger... Keep up the efforts....
T
Tinster
Now Paul!
This seems to be a wide spread failure and only indirectly
can I blame it on DPO. Many other folks got burned on
this fuel pump failure.
Ture, I purchased the pump as a spare for when DPO's
pump failed on me. And it DID fail on me as predicted.The
defective spare got me back home and saved me the cost of
a very pricey $$ flat bed trailer tow.
Now the $750 I spent to correct the flooding rear carb
with custom crafted fuel lines, multi-filters, etc and
taking out the fuel tank and refurbishing it?
That would all seem to be a total waste of my time and cash.
d
dklawson
Randall, those are excellent prices on the Facet pump. Thanks for the link.
BTW, the Purolator regulator is the one shown in the first of the two links in my previous post. That's the one I have been told to avoid. I have used them and I found their "scale" or selector dial to be very inaccurate.
TR3driver
Not a total waste ... hopefully you learned some important lessons about owning and wrenching on old cars /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
One of them being : Not all "improvements" are better /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
tomshobby
TR3driver said:
I agree, I have had several transactions with this company and have been very satisfied with them.
Also, I just placed an order for this pump and they are being back ordered with an expected delivery of the third week of July. The price is about 1/3 that of another supplier.
Cyberpyr8
Have you ever considered moving to the states where AAA can tow you? I know it's a lot to move your family just so that you can get car parts and a cheap tow, but it is a Triumph!
Seriously, I know you have had a string of problems with the car. If anything that should be reassuring that the car is ok and it was just a defective part.
T
Tinster
Randall:
I plead total ignorance of elec. fuel pumps.
Do they go inside the fuel tank?
or are they in-line pumps with gravity flow from
the fuel tank into the "in" port of the pump and then
the pump pushed to fuel along?
From the site you posted- which specific model number
would be purchased for Crypty.
Would this be a backup- parallel system to the manual
pump and hoses?
mctriumph TR2/3/3A Defective master cylinders Tr3 Triumph 13
D TR2/3/3A Distributer defective? Triumph 7
T Defective rocker arm shaft photo Triumph 12
J Defective replacement Leaf Springs? Spridgets 3
angelfj1 Caution - Defective Wire Wheels Restoration & Tools 0
2wrench Heater cable & knob probably not defective Triumph 1
kyreb1862 Defective Oil Filter MG 12
guzzul Advice on diagnosing defective fuel pump.... Triumph 9
K TR2/3/3A Mystery TR Part Triumph 9
I MGB Help! What is this part for? MG 13
R Part Identification Austin Healey 5
Agrandshort TR2/3/3A Unknown part panel Triumph 5
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
J TR2/3/3A Part Identification Triumph 7
CARSINC Unknown Part Spridgets 5
equiprx Mystery part Other British Cars 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
N MGB Electrical Part Identification MG 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
R Cool Remanufactured Part for Vixen 2500 TVR 7
N MGB Name that part MG 5
D TR2/3/3A Another mystery part(s) Triumph 2
P Wanted Part # BHA5138 Triumph Classifieds 0
AngliaGT MGB Dumb Question - What's This Part? MG 3
D TR2/3/3A Another mystery part Triumph 8
B Useful Part or Boat Anchor? Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
B TR2/3/3A Hard Top Part Triumph 2
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
Healey Nut Mystery Part Austin Healey 2
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
vping T-Series Looking for TD Part # MG 3
D TR2/3/3A Another mystery part..or two Triumph 14
T Trying to identify a steel plate part Austin Healey 2
Bayless Missing important part Spridgets 0
H TR2/3/3A Rimmerbros Part Triumph 7
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
Lin TR6 Do you know this part? Triumph 6
Lin Name this part - I am stumped! Austin Healey 24
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
tr6nitjulius General TR Part 3 What We Missin' Triumph 0
tr6nitjulius General TR What we missin' part 2 Triumph 0
T Wedge TR7 engine, need help identifying part. Triumph 5
tr6nitjulius General TR What We Missin' Part 1 Triumph 0
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
