Crypt Car Progress Stalled
T
Tinster
I need a little help here from the experts.
I'm a little over my head with this clutch
replacement.
This morning I was cleaning up the tranny, etc.
and I noticed right off the new clutch kit I got
from TRF has different parts than the ones I removed.
I tried to dry-fit the new T/O bearing fork,
taper pin and clutch pedal bar and they were
a no go.
The old bar I removed has a groove cut into it near
the end of the shaft. A bolt from outside the tranny
case runs thru the groove and holds the bar in place.
The new shaft has no groove and nothing to hold it
in place.
Do I need to take the new shaft to a machine shop
and have a groove cut into it to match the old shaft?
Here is a photo of what I have. And yes, I will
install a back-up taper pin in the fork.
Thanks as always, Dale
gjh2007
Dale:
According to the Moss diagram there is no locating bolt; I can look at both my trannies tonight when I get home. I believe the clutch fork is held in place by the fact that the throw out bearing will center itself on the pressure plate any way; but I have been wrong before!
Anyone with additonal recent info please chime in.
Check this link:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32782
TR6oldtimer
The bolt you reference is a locating bolt used on TR4A and earlier transmissions. This feature was not used on TR250 and up transmissions. You need not worry about it, but if you do, then you need to order the shaft for the TR4's which will include machining for grease fittings.
Ray
Alan_Myers
Hi Dale,
Earlier TR gearboxes had that groove in the shaft to keep it from moving side-to-side. At some point that was discontinued and the retaining bolt was omitted. This leaves only the fork itself to keep the shaft aligned in the gearbox. IMHO, this might put more side-to-side stress on the dreaded taper pin and/or the two pins in the fork that interact with the throwout bearing carrier. Personallly I'd want the retaining bolt and slotted shaft, if at all possible.
I suggest you return the shaft and ask them to send you one with the groove in it (I know TR4s used it, not sure what other models). You could have the shaft modified locally, but the earlier ones with the locking groove and the even earlier ones with both the locking groove and the grease passages are easily available through the various vendors.
Speaking of which, while you are at it, you might want to specify the clutch cross shaft that's drilled for greasing, too. It has threaded holes in each end that allow grease zerks to be installed. Those holes lead to short drilled passages that route the grease to the bushings in the bell housing. The later cars don't have this. Later cars also use a smaller, approx. 3/8" wide bushing in the bell housing that is plain inside. The earlier ones had an approx. 3/4" wide bushing that gives more support to the shaft *and* is drilled and grooved inside to give the grease a path to work into the area. All it takes is a quick one or two pumps with a grease gun every year or two to keep the greasable-type of assembly fresh and working smoothly. The later, greaseless-style with the narrower bearings wears faster and might get a bit stickier over time, putting more strain on the rest of the linkage mechanism.
At some point I think you said you have an engine from an earlier car (TR250?). Perhaps you have an earlier gearbox, too. It might already have the 3/4" bushings in the bellhousing (although I doubt it since the shaft isn't drilled for greasing). A possible clue... first locate the gearbox serial number. Beginning with TR4 and on all later TRs it's on the boss that sticks out on the LH side, that the cross shaft runs through (Moss shows its location in their catalog). Look of the rearward face of that boss for a stamped serial number which starts with two letters, followed by a short series of numbers.
The two letter prefix of the gearbox serial number can tell you what TR it was originally built for. "CT" is TR4/TR4A, "CD" is TR250/early TR6, "CC" is 1973-74 TR6 and "CD" is 1975 and later TR6. "CP" was also matched up to some 6-cyl., but I'm not sure which model. There are other prefixes such as "MD", "ME", "MG", "MK", "VA"and "VF" indicating the gearbox came out of one of the Triumph sedan car models. "TS" and "UF" indicate a gearbox lacking first gear synchro that was originally fitted to TR2/3/3A. Finally, "GR" was used to indicate a factory rebuilt gearbox and might appear in any of the cars.
There are some other visual clues, too. For example, the flange attaching the gearbox to the engine (yours only had a few metric bolts in it, right?) was beefed up on the later cars. It's roughly 1/2-5/8" thick at the bolt holes, I'd guesstimate. The earlier gearboxes were only about 1/4-3/8" thick at those points. Also, the earliest gearboxes have a long input shaft that sticks out past the edge of the bellhousing. I.e., if you stand the gearbox on end it can't sit flat without a couple blocks of wood under it. The TR4A and later with the newer diaphragm clutch use a shorter input shaft that allows the gearbox to sit flat when on end.
All this is a bit of a moot point, though. Any gearbox could have been rebuilt with different input shaft, internal parts and gearing, and installed in any car. The external housing and the serial number aren't necessarily a guarantee as to what's inside. There were slight changes over the years, including gear ratios, etc. So, hopefully, the innards match up to the serial number if you ever need any internal gearbox work done.
The clutch release shaft you're working on right now was made in several variations, as you can see. But all *are* interchangeable, so no worries there. Again, I recommend using the earlier, greasable version (circa TR4).
Are you installing a new release fork too? I ask because they have two nubs or pins on the inside of the fork tines that interface with the throw out bearing carrier (aka clutch release bearing carrier). Used fork pins tend to get worn flat on two sides. These can be replaced, if needed. Knock the old ones out, press fit in new ones and peen them a little to help keep them in place. A new fork would most likely have new pins installed. A "cheat" here is simply to get a good grip on tje worn old pin and turn it 90 degrees, so that an unworn area is now engaging with the TO bearing carrier. This reduces slop in that area, which can contribute to clutch problems if it gets bad enough.
While you are working on all this, it's also a good idea to replace the clevis pin at the slave cylinder pushrod, if it shows any wear, is a sloppy fit. The hole in the slave cyl. pushrod can get worn oversize, too. Now there are adjustable versions of those pushrods now being made for TR6, too. They originally came with non-adjustable type. The earlier cars had an adjustment there, but Triumph eliminated it on the later cars. Adjustment is a good idea to help insure full and accurate clutch release.
Also, there is no external return spring on the slave cyl of the later cars. They rely on a spring inside the slave cylinder itself I think and the clutch's own return springs to move the linkage back. The external return spring is another easily retrofitted item, if you wish. There's just a hole in the clutch slave bracket for one end, and a special little tab that fits under the clevis pin at the other end. This just makes for some added security that the slave cyl will retract all the way properly.
If this sounds like you are taking giant steps backward by retrofitting TR4-era parts to a TR6, keep in mind that the earlier cars' clutches seemed to last forever, while later cars have had all kinds of problems.
When Triumph went to the diaphragm clutch in the TR4A and later cars, in several steps they changed the setup to reduce servicing and, probably, to save a few bucks. Plus they modified it a bit to make the pedal a little more "user friendly". Unfortunately, this was all done at a cost to reliability! To make matters worse, the 6-cyl. engine developes more torque than the 4-cyl, and thus puts a bit heavier load on the clutch mechanisms.
The later diaphragm clutch you have *is* preferable (and not directly interchangeable due to mounting holes in the respective flywheels). This is because it's a more modern design, smaller and much lighter in weight, plus cheaper and easier to find.
If intereseted, all the "retro" parts can be seen at Moss website. Just look up the exploded views showing the clutch linkage for TR4, instead of TR6. Given a choice, I'd use the earlier clutch master cylinder, too. The pedal will be a bit heavier, giving your left leg slightly more of a workout, but the .75" master cylinder gives a bit more stroke at the slave cyl. and a more certain, complete release of the clutch.
T
Tinster
Andy & Ray-
Really curious now.
I've traced the engine block and it is certainly
a 1968 TR250.
1969 dashboard and 1969 steering wheel.
1971 seats I believe and 1970 wheels.
When the tranny locked up in second gear, I took
apart the gear shift lever mechanism. A very tiny
spring and tiny metal button were missing from
the very bottom of the shifter shaft.
I ordered the two new pieces which according to the
parts catalogue were used from year 1973 and forward.
I installed them and the Beast shifts just fine.
There are identical locating holes on BOTH sides of
the tranny so either right hand or left hand cockpit
could be used. If that is any help in identifying the year.
A most curious vehicle.
thanks as always,
dale
swift6
Sounds like Pedro the parts boy has done some interesting mixing over the cars life. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
TR6oldtimer
Dale,
I looked at an old TR250 trany I have, serial number starts with CD (as it should) and it looks just like ours. That is, it does have holes to retain the clutch shaft. So you can go with what you have or go as Alan recommended with the earlier shafts and bushings.
Ray
T
Tinster
Wow! Alan and I must have been writing at the same time.
The clutch master and slave cylinder and all components
are TRF new, as is the SS braided hydraulic hose that
connects them.
I purchsased TRF magic clutch kit along with their T/O
bearing, shaft, fork, taper pin, shaft bushings kit as well.
I will print out Alan's narrative and take it with me
Friday, if I have time to drop by the car. I am curious
myself what odd combination I have.
Alan, I have an appointment Friday afternoon to meet
with a machine shop to follow your instructions about
drilling a 1/8" access hole into the taper pin as well
as thru drilling for the 1/4" secondary fork bolt.
Maybe I best put that on hold. I'm kinda confused right
now. I think I need to lock down what modle tranny I am
working with.
To compound things, the exhaust header and pipes are
vintage high performance- 6-3-1 I think. or 6-1
thanks all,
dale
T
Tinster
Lord give me strength!
Job in the bible must have been a
distant relative of mine!
A year ago, freakin' Pedro told Wendy all
the Crypt Car needed was a new ignition switch/key.
But Hey!! The radiator blew up before I could
get that new key.
Wow! Expensive key, that one.
d
martx-5
Yeah, but just think of what a great mechanic you're turning into. Besides that, it's because of all of your trials and tribulations with the CRYPT CAR that we have succeeded in passing the MG forum in total post count. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
G
Dale, have you ever considered going into the business. I can see it now, in neon yet: DALE'S BRITISH CAR REPAIR, LTD.
No?
Harry_Ward
Hmmmmm. LTD. I guess you could do the same thing the town mechanic does to me. Every time an operator drives a piece of equipment out that he recently repaired he turns to me as soon as it is out the repair bay door an says warranty's up! Send in the next one!!!
T
Tinster
I'm still trying to identify the type of tranny in the Crypt Car. I took a closer look yesterday and this is what I found:
Mounting flange 5/8" thick at bolt holes.
3/4" wide bushings
The inner shaft DOES NOT protrude past the housing
plane. The wide end side will sit flat on the floor.
The numbers and lettereing a very confusing and do not resemble anything anyone has posted.
Here is photo of the Crypt Car tranny left side.
The wide portion of the tranny has the word "Standard"
embossed on it, nothing else. The narrow portion is in
the photo.
The right side of the tranny has 306812SM embossed
in the wide portion of the housing. The narrow portion has WYF E3559 embossed on it.
So, anyone have any ideas what type of tranny the Crypt car has?
Help is greatly apprciated. Dale
PeterK
If the input shaft is flush with the housing, it's pre TR250. Look for the stamped serial number on the flat on the left side of the gearbox, on top of the clutch shaft boss to get the specific model it came from.
Brosky Tinster's Crypt Car - Any progress??? Triumph 27
T No more test drives for The Crypt Car. Triumph 7
T Today might be the demise of the Crypt Car Triumph 19
T Crypt Car EnduroRun proposed. Triumph 44
T Crypt Car found a cousin ! Triumph 13
T TR6 My 1969 TR6- the Crypt Car Triumph 42
T Crypt Car diagnostics-step 3 Triumph 42
T A Crypt Car moring drive Triumph 36
T Crypt Car Latest Triumph 19
T Crypt car driving in the dead of night Triumph 10
T crypt car Latest Triumph 6
T The Crypt Car returns Triumph 45
T Return of The Crypt Car Triumph 13
T Son of Crypt Car-Up-date? Triumph 5
T More of Crypt Car trashed Triumph 30
T New Crypt Car problem Triumph 16
B Crypt car comes to America...sort of... Triumph 20
T Crypt Car Brake Failure Triumph 64
T Crypt Car is Broken Again Triumph 59
Brosky Sneak preview of Crypt Car running Triumph 15
T Crypt Car News Up-date Triumph 29
T Crypt Car Clutch Question Triumph 23
T Crypt Car dies in street Triumph 17
T Crypt Car needs a part Triumph 9
T Adios Crypt Car ! Triumph 10
T Crypt Car Ignites Successfully [kinda] Triumph 125
T Paul,Bill, et al- Crypt Car back up posting Triumph 9
G The Crypt Car for Halloween! Triumph 3
T Crypt Car punching back Triumph 40
T Crypt Car Set Back Triumph 67
T Crypt Car blew up today Triumph 39
T No Car Crusher for Crypt Car- life spared Triumph 21
T Crypt Car Won't Start. Advice? Triumph 20
T Dan Master Wires and the Crypt Car Triumph 21
T Crypt Car Up-date Triumph 18
T Of Hondas and Crypt Cars Triumph 11
NickMorgan The Crypt Diary Part II Triumph 6
T Crypt Up-date Triumph 28
T Report from The Crypt Triumph 10
T Crypt Clutch 2nd Look-see Triumph 203
T The Lost Crypt Thread Triumph 20
A Why is my car making this noise? FORUM Navigation Questions 0
N Wanted Help with car identification Other British Classifieds 2
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
