TR2/3/3A Crank Pulley
Scotsman
When reinstalling the crank pulley after having the timing cover off (replaced gasket and seal), should the crank shaft/pulley have any sealant applied to it. It seams reasonable to think oil could seep between pulley and shaft. If so what should be used. I don't want to glue the two together and make them impossible to come apart.
TR3driver
Great Pumpkin - R.I.P
You shouldn't need anything there, the joint gets clamped very tight when you tighten the big, long bolt. Oil shouldn't be able to make it's way even in to where the hub fits onto the shaft.
But it also wouldn't be impossible to get off if you did glue it together. On my previous TR3A, the crank nose was worn undersize (from the hub coming loose and not being noticed for a long time), so I used Loctite "Circular parts mount" to restore the fit. It took a bit of creativity to hook up a puller to it, but it popped right off once I did. I put a spacer through the center of the crank, and long bolts from the puller through the holes that hold the pulley halves to the hub.
sp53
If you are concerned, you might try some heavy grease like wheel bearing grease for disc brakes. The stuff should get trapped in there and create a seal.
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
T Replacing the crank pulley/damper Austin Healey 4
M Crank Pulley Removal Austin Healey 12
J General TR Narrow Belt crank pulley Triumph 0
B Chip off the crank pulley Austin Healey 12
PatGalvin TR2/3/3A TR3A Crank pulley removal Triumph 9
RickB Not Midget Related [mostly] Removing crank pulley Spridgets 6
B TR6 Tightening crank pulley bolt on TR6 Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
J Removing Crank Pulley Nut Austin Healey 5
H TR2/3/3A TR3 Crank Pulley Removal Triumph 12
eschneider MGB MGB crank pulley tool MG 12
Sarastro Crank pulley removal Spridgets 18
drooartz Removing crank pulley and flywheel Spridgets 16
RandallRK Timing mark on crank pulley Austin Healey 19
L Crank pulley socket? Triumph 10
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
A crank pulley timing marks Austin Healey 2
spiny Hello, possible stupid question .... crank pulley Spridgets 21
Lin Crank pulley measurement Austin Healey 2
Morris 1500 crank/pulley nut removal Spridgets 39
A Crank pulley question-- for you engineer types Triumph 7
G Crank Pulley Stuck Triumph 1
hvacr crank pulley seal MG 2
waltesefalcon Crank pulley nut Triumph 7
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 22
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
