Compression Testing
wooolffy
Member
Just going to check compression, what is proper method? Throttle open, fuel off, plugs out, coil wire off. Any thing else? /ubbthreads/images/graemlins/driving.gif
Geo Hahn
[ QUOTE ]
...Any thing else?
[/ QUOTE ]
Make sure the gearbox is in neutral (not that I have ever run over my own foot).
K TR2/3/3A Compression testing again... Triumph 4
MadRiver Testing Compression MG 1
tahoe healey compression testing Austin Healey 32
J compression testing Austin Healey 15
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 3
petnatcar Compression Test Record Form Austin Healey 0
W Cylinder compression Hillman super minx Other British Cars 15
Donald1107 TR2/3/3A low cylinder compression Triumph 12
kodpkd Compression Test Results Austin Healey 1
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
Martinld123 Compression check 1956 BN2 Austin Healey 7
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
