TR2/3/3A Clutch slave stay rod
CJD
Found another missing part...it's the stay rod for the clutch slave cylinder, pn 106702. This is the brace rod that goes from the slave bracket to the engine oil pan bolt. Apparently the early one was up to TS13046, and a newer version after. So, I know what the later one looks like on my TR3a, but I have no idea what the difference is. Does anyone have a picture or discription? Like, does it take a different route around the downdraft tube, or attach to a different pan bolt?
sp53
Some of the older books show that smaller slave cylinder in there pictures, but I do not know if it goes back that early. If I remember correctly, the difference is what side of the bracket the cylinder bolts to.
CJD
CJD
Thanks, Steve. All I know is from checking the parts list and big three. They list a different mounting bracket for the slave cylinder prior to TS13046. The cylinder is shorter and fatter looking on the earlier version, so I imaging the bracket has a larger cutout. Of course all the early versions are NLA. I have the original bracket, and the rod is just a rod, so I can fabricate it...but a pic or two would get me started. Do you remember which books showed the early set-up?
CJD
CJD
I found it, so the emergency is over! It's coming from Rimmer bros out of the UK. For once shipping was not more than the cost of the part. Looking at the picture for the part, I couldn't tell what the difference is. When I get it I'll post for posterity...it'll probably be so close to the newer rod that I could bend the new to work, but we'll see.
Now for those wire wheel hub collars....
sp53
Yeh the Triumph Sports Car—illustrated Book on page thirty one shows a tr2 slave cylinder. Actually I think the whole booklet shows tr2. The book is the owner’s manual that came with the cars
sp53
Looking closer the book shows what looks a 56 or 57, but the pictures look like those artist drawn deals, so who knows how old they are, but it is early stuff. I had to edit my post of your ignition switch comment to “I did NOT know that” because it sounds like I was being a wise guy when I left out the word ---NOT.
CJD
CJD
No sweat! LOL...Modern spell checkers teach us to read through the odd word here and there.
CJD
CJD
Got the new stay rod. It is, indeed, very different from the later TR3 style. There are three bends in three different planes. Anyway, one more part accounted for!
One final question on this topic...anyone happen to know the thickness of the spacer between the oil pan and stay rod?
sp53
Hey John I have what I believe to be an original set up and the wash is about 3/16 think and Âľ wide. I will look around and see if I can find another one.
CJD
CJD
Thanks Steve. For some reason I thought it was taller, but I guess it just needs to clear the lip on the oil pan. Glad I asked!
sp53
John I just had to clarify this post. The knob/loop on the back of the clutch support stay-rod will act as the spacer. The picture I posted was the spacer for the connecting bridge piece between the breather tube and the oil pan. The power of suggestion is interesting because I thought there was a spacer also, and looked all over for one, but when I put the stuff together this week I remembered/noticed the difference.
CJD
CJD
Thanks, Steve! I got under Marv's old car to see if I could steal the spacer from it. It didn't have a spacer, so I just set the parts aside to determine later whether it needed one or not. Good to know I'm not missing a part...for once!
By the way, I'm starting to get jealous. It sounds like you're leap frogging ahead of me! I'll be slowing down for a while, as my daily driver Jag with a V12 just swallowed it's timing chain tensioner. A little part held with 2 bolts, but the whole front of the car has to come apart to get to it. So...I'll be following your posts while you scout ahead!
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Clutch slave "return spring"? Triumph 3
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
R clutch slave cylinder Triumph 11
W Clutch slave cyl. Austin Healey 4
S XJ6 Mk1 clutch slave question Jaguar 0
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
A clutch Slave boiling Spridgets 6
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
RickB MGB Trouble bleeding new clutch MC & slave MG 6
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
K TR2/3/3A Resolving my Clutch slave issue.... Triumph 3
RedTR3 TR2/3/3A Clutch Slave Adjustment Triumph 5
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
RJS TR4/4A Clutch Slave Size? Triumph 5
G MGB STILL working on clutch slave MG 37
G MGB Clutch Slave Cylinder MG 34
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
D Clutch slave travel Triumph 12
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
tahoe healey Clutch slave upside down Austin Healey 5
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
T Could someone measure a 1500 clutch slave pushrod? Spridgets 15
