clutch slave cylinder
Hairyone
bugeye with 1275 engine & box:
I've just had to change my dual master cylinder coz it was weeping. It was a 7/8" I've discs up front so brought the 3/4" master. I know the clutch is a bugger to bleed & have searched on here how to do it. I now have the slave cylinder removed & hanging down under the car & it's inside diameter looks a little big, about 1".
Who knows what the slave diameter should be for a 1275 with disc brakes & a 3/4" master?
Thanks
Hairyone
Hairyone
Clutch woes:
I know this is a bugger to bleed & I know I've got all air out now, having read all about it here. But I still can't dis-engage clutch.
I've done some calculations on clutch slave travel (in metric as it's so much easier, 1" = 2.54cm).
I had a 7/8" master & the 1" slave: Presume the master pushrod travels 2cm (3/4") into the master, may be a little OTT. The fluid displacement = 7.74cc put that into a 1" slave and it's pushrod travels 1.52cm.
Now with the 3/4" master and the 1" slave travels 1.12cm, considerably less.
I know my clutch slave pushrod is worn (elongated hole) but the piston is also near the end of the cylinder. This says to me one of two things:
1/ my pushrod is too short, mine is 2 5/8" from end to middle of hole. I need a new one, but how long is it supposed to be?
2/my clutch or bearings etc are near end of life.
What have others uses with this combination? My thoughts are 7/8 slave which will give me 1.34cm of travel. ??????????? :hammer:
JPSmit
One other thought is that the inside of your MC (and/or maybe your slave) is pitted. I could not get my clutch pedal to return properly and that is what it was - at that point it was time for a new MC.
Hairyone
Hairyone
um nice wrench, but I don't have a problem with bleeding. I un-bolted the slave, pushed up the piston & clamped it up & used an eazybleed @ 15psi.
My cylinder is clean inside, no rust & 1" dia. My master is new 2/3" I was just wondering if this is the correct size combination???
lesingepsycho
I don't recall for sure but it seems like I remember hearing about different length pushrods.
JACK
Billm
Harry
Don't bother with getting another slave, I seriously doubt that it will work.
One of the easiest ways to remedy (notice that I DIDN'T say "fix") this condition is to remove the slave push-rod, thread it to 5/16-24 UNF and thread a nut in it (preferably a "coupling nut" which is about 1" long) and rreplace the unit in the car. Now unscrew the nut until the slave is pushed almost all of the way into the cylinder (giving the linkage about 1/8" slop).
It should now work just like advertised.
BillM
spritenut
Did you put the rods from the 7/8 master in the 3/4 master?
The 7/8 master rods are much longer and will not work in a 3/4 master.
Hairyone
Hairyone
I don't know what rod is in there but it's 2 5/8" long, which seems a little short as the slave is nearly all the way out.
I believe I need a longer one (don't we all :cooler: ), but also more movement, hence my calculations & I've lost a bit of that when swapping to the 3/4" master.
Does anyone have part numbers for the longer pushrods & perhaps the 7/8 slave?
jlaird
Longer rods are easy, always wanted to say that, even adjustable ones. Have a bolt brazed on the end of the rod and grind it round..
HOWEVER, first put a nut in the cylinder so the rod will push on it and see if the longer rod is appropiate.
Sarastro
By going to the 3/4" master, you've lost about a quarter of your motion at the clutch release lever. That's not good, but I'd think you could still release the clutch if all else is OK.
The slave cylinder is "self adjusting": it should pump up until there is very little slack in the pushrod; i.e., the release bearing is almost in contact with its mating surface on the clutch pressure plate. Then as long as things are adjusted right so there is no slop at the master cylinder, so you get a full stroke when you push in the clutch, you're doing about as well as you can.
It's possible to have a master cylinder rebored or sleeved so you can have 3/4" for the brakes and 7/8" for the clutch. Take a look at Sierra Specialties' web site, https://www.brakecylinder.com/, or similar places.
Also, if you can't get all the slack out of the pushrod/release lever assembly, consider BillM's solution seriously. I've had to make my own pushrod on occasion to make it all work right. If the pushrod is too short, the piston in the slave can hit the retaining snap ring, preventing you from getting enough motion. Not all slaves have those, however.
Hairyone
Hairyone
Thanks all for advice. I'm doing two things; ordered a longer pushrod & a 7/8 slave. Once installed next week sometime, I'll report back with success rate, part numbers & pushrod length.
Ta.
Hairyone
Hairyone
Yipee, all works now:
Here's what I have for anyone else in this situation:
Frogeye with 1275 engine & box, converted to disc brakes but using the dual master.
new 3/4" dual master.
new master pushrods (Moss 13H3655) cut down to suit (1/2" off)
7/8" clutch slave (minispares GSY110 (LL10469))
Slave pushrod (moss AHA6409) with the spare bit from the master pushrod welded on the end.
master pipe GPP56AA (this is the smaller diameter pipe).
Goodridge Flexi hose C-AJJ4025
Results: clutch a little softer. Brakes work well, but not tried in anger yet. :driving:
jlaird
Lovely, glad it worked out.
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
M clutch slave cylinder? Triumph 5
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
O Clutch Slave Cylinder Travel Triumph 5
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
Slider748 Clutch slave cylinder question. Help! Triumph 8
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
