T-Series Clutch Slave Cylider Hose
MikeH
Hi All, What's the chance that NAPA would have a hose for a 71 MGB clutch slave? Slim and None? Thanks, Mike
71 MGB OD & Wires
63 TR4 Surrey Top
Platinum
You may be surprised. Worth a call.
ccougill
if they don't have it they can probably have it next business day, I've had really good luck getting stuff from O Rellieys and Advance Auto that way
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Clutch slave "return spring"? Triumph 3
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
R clutch slave cylinder Triumph 11
W Clutch slave cyl. Austin Healey 4
S XJ6 Mk1 clutch slave question Jaguar 0
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
A clutch Slave boiling Spridgets 6
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
RickB MGB Trouble bleeding new clutch MC & slave MG 6
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
K TR2/3/3A Resolving my Clutch slave issue.... Triumph 3
CJD TR2/3/3A Clutch slave stay rod Triumph 11
RedTR3 TR2/3/3A Clutch Slave Adjustment Triumph 5
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
RJS TR4/4A Clutch Slave Size? Triumph 5
G MGB STILL working on clutch slave MG 37
G MGB Clutch Slave Cylinder MG 34
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
D Clutch slave travel Triumph 12
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
tahoe healey Clutch slave upside down Austin Healey 5
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
