clutch engaging far up the pedal
Jerry
My clutch starts engaging when the pedal is more than half way off the floor. As far as I know, there is no adjusting of this. Anybody know any different. I am use to the clutch now but everyone else that drives the car says it feels weird.
Jerry
BN4
Dave Russell
Yoda - R.I.P
Jerry,
I'm not exactly sure. A worn clutch disc (thinner than normal) would cause the problem. If it IS disc wear you will eventually reach a point where the clutch starts slipping as the release bearing gets topped out.
There is a possibility that the flex hose is severely restricted internally & causing slow engagement. But I think you described the problem as everything acting normal except a higher engagement point. Has it always been this way?
J
Jerry
No, but I had to replace the clutch about 2000 miles ago due to some break in problems with the master clutch cylinder installed wrong. It seems to work fine but expectations are to have the clutch engage a littler earlier than it does. Well, at least it runs and we had a great time on the Halloween rally yesterday. The designer had our paths cross at various times so you never knew who was lost. We found out later that the there were two different routes. Lots of stares at the cars and the people dressed up in costumes.
Jerry
Which Healey club are you in? I hadn't heard of a Holloween rally in Sacto. Most of us in Northern Calif are in the Golden Gate.
Have you checked for a drop in the fluid? (sorry very obvious but you may have some air in the line if poorly blead. I had this problem on my XK140)
J
Jerry
United British Car Club out of Sacramento. I met you on the Miata/Healey tour through the passes a few years ago. I had the dark blue/white 100-6 with the hardtop. All other clubs are invited to our rallys. The more the better.
The fluid level is fine. Never leaks. I will check for bubbles and re-bleed the system. Any other ideas?
Jerry
BN4
[ 10-26-2003: Message edited by: Jerry ]</p>
Dave Russell
Yoda - R.I.P
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Jerry:
Jerry
<hr></blockquote>
Jerry,
If it didn't do it before you replaced the clutch & it DOES do it now the problem must be related to the last change. It's always a good idea to check the thickness of a new disc for about .330" with the Marcel spring compressed. There is something different between the new & the old. Probably nothing to worry about.
That wasn't me you met. There are three other Big Healeys up here. Mine is white. The others are champain, dark green and a lighter green.
If you changed the unit out, what kind of fluid did you use?
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
R General Tech No Triumpn - Healey 3000 Clutch not engaging Triumph 18
R 1959 3000 Clutch not engaging Austin Healey 17
jfarris TR2/3/3A Clunk when engaging clutch Triumph 1
B Help..Clutch not Engaging..Cant Shift Spridgets 4
kodanja Clutch not engaging Triumph 12
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
