T-Series Clutch Adjustment
MikeH
Is there a way to adjust clutch engagement and disengagement? My clutch releases with less pedal movement than I like, and the Bentley manual doesn't show any adjustment. Thanks,
tony barnhill
Great Pumpkin - R.I.P
No adjustment on MGB clutch
1965_MGB
Since it is a hydraulic clutch, there is not adjustment. It should be fully engaged about half way up. I would check the rod on the slave cylinder to see if it might have elongated. That could cause less travel in the slave.
Platinum
The other thing to check is at the clevis pin and pedal under the pedal box cover. The pin and pedal should have a good fit, NO freeplay to speak of... if the pin/pedal are worn you will have noticeable lack of travel at the slave cylinder.
M
MikeH
I have plenty of travel, the clutch releases and re-engages after 1/4 down and 3/4 up on pedal. My TR4 has a threaded rod at the slave for adjustment, hoped the MG had the same. Oh well. Thanks,
Platinum
ah. Sounds like you may be in for a clutch R&R in the future. When you said "less pedal movement" I misinterpreted it to mean it was coming in too close to the board. Sorry.
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
R TR2/3/3A Clutch Petal Adjustment Triumph 2
M TR6 clutch adjustment Triumph 4
R TR2/3/3A Clutch Adjustment Triumph 18
6 Clutch Adjustment Spridgets 2
Jim_Gruber BE Clutch Adjustment Bugsy IV Spridgets 7
K TR2/3/3A Clutch adjustment with mixed TR parts? Triumph 10
RedTR3 TR2/3/3A Clutch Slave Adjustment Triumph 5
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
Zimmycobra TR4/4A TR4A Clutch adjustment question Triumph 2
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
jhorton3 Rivergate Clutch Adjustment Spridgets 6
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
CJD Brake/Clutch pedal adjustment Triumph 29
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
Nelson Clutch slave adjustment Spridgets 6
J Clutch Adjustment? Spridgets 13
P clutch adjustment on 79 midget? Spridgets 6
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
B TR6 Clutch Adjustment / TR6 Triumph 5
AUSMHLY Clutch pedal adjustment Austin Healey 6
Hegg Elan +2 - Engine Mounts and Clutch Adjustment Lotus 6
Darwin Clutch Pedal adjustment. Triumph 4
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
