Brosky
Dale was asking about the timing marks on a damper. This is the result of too much time to think of things to do when the damper was off the car.
This requires removing all paint from the outer surface, washing with acetone, applying the tape in exactly the right position relative to TDC, letting it set and then applying multiple coats of clear to protect it.
Also, applying it in the proper direction helps as well.
