Cleaning large assemblies.
Simon TR4a
Looking for advice on cleaning engine block, rear axle/diff and other large items.
I have a small pressure washer, should I use detergent and pressure washer, or solvent like Varsol and a paint brush?
Simon.
Rick O.
Buy a gallon of the purple degreaser and put it in a spray bottle. Spray everthing down with it and let it set awhile. Then hit it with water (hose or pressure washer).
trrdster2000
Wear old clothes and eye protection, the water will always catch an edge and come right back at you, but it is the best way. Wayne
mailbox
Make sure you oil everything down after you clean it to prevent rusting. /ubbthreads/images/graemlins/grin.gif
PeterK
You can always take them to the carwash at night and use their pressure. I had my block hot tanked after I cleaned off the outside with 2" Scotchbrite pads on a die grinder and a wire brush on a right angle grinder. For the rear-axle, I blasted it outside with black beauty, then had it hot tanked before repainting it.
For smaller parts, anything that will fit in my blast cabinet gets glass beaded before I powdercoat it.
L TR2/3/3A Stupid Engine cleaning question Triumph 9
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
JPSmit Cleaning parts tonight Spridgets 6
regularman Spent the day yesterday cleaning and painting Spridgets 9
Darrell_Walker Head cleaning Triumph 16
M Help ID part, Cleaning house Jaguar 8
bighealeysource Cleaning up aluminum on Healey hardtop Austin Healey 7
Darrell_Walker Alternator cleaning ideas Triumph 10
A Cleaning convertible top Triumph 7
dougie Spring Cleaning Austin Healey 18
jlaird Cleaning out Spridgets 0
K Further to carb cleaning ...careful with SU domes. Triumph 7
