Clean behind the Grill on a 100
Pizzi348
Now that the driving season is winding down, I'm starting to clean my cars for their winter naps. Behind my grill, in the empty space, it got pretty dirty. How can I get behind there and clean it? My thought was to remove the grill, but I'm not sure how to do that. Any ideas? Pictures even?? Thanks!
The grille removes easily after you unfasten from the inside the--five I think--nuts that secure the corners and top edge. You can do this through the wheel wells.
If your car is an overheater, esp. in traffic, now would be a good time to consider an electric fan that fastens to the braces in front of the rad. You will have to remove the vertical divider which serves no purpose other than preventing one's seeing "airspace" through the wheel openings when viewing the car from the side.
glemon
Michael is exactly right, I will only add that if you can get a squirt of WD40 or PBblaster on the nut and stud before removal so much the better, as it is possible to break the studs off (you can probably figure out how I know.
You can get in there by turning the front wheels to full lock so you can get your arm in there, a racheting wrench works well for this job.
Greg
P
Pizzi348
Thanks Guys!
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
T How do I clean sand out of a ring & pinion? Spridgets 2
F After 30 years of ownership I decided to clean my 1961 Healey 3000 BT7 Austin Healey 0
BoyRacer How to clean a cloth wiring harness Austin Healey 14
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D TR2/3/3A Exhaust manifold clean up. Triumph 6
I General TR Mold clean up suggestions Triumph 4
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
R General TR Best way to clean unpainted parts Triumph 1
jaegzie Cylinder wall has some build up. Need to clean. Spridgets 4
NutmegCT Cooling system clean/flush Restoration & Tools 11
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
nevets How to clean a E Z Bleed ? Restoration & Tools 11
C How to clean a Lucas Headlight? Restoration & Tools 5
R did a little clean up today Triumph 5
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
Darrell_Walker Fuel tank - just clean, or clean and seal? Triumph 15
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
T silcone clean up Triumph 9
Moseso Mini ! Clean! Also, heavily customized ! Spotted 2
bighealeysource How to clean up rear backlight on factory hardtop Austin Healey 11
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
Rut Transmission clean up Restoration & Tools 5
W Garage clean up Spridgets 0
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
J Paint help! [I've got a mess to clean up] Triumph 9
D Wire wheel clean prior to paint MG 1
ekamm Clean looking sedan on Eastcoast Triumph 0
M What's the best way to clean off under-gunk? Spridgets 10
T best way to clean a canvass top? Triumph 4
T Working with clean parts is soooo very nice Triumph 19
SilentUnicorn How not to clean a motorcycle chain British Motorbikes 6
tmc Clean the gas tank or buy a new one? Triumph 8
J what should I use to clean 30yr old vinyl? Triumph 6
T Radius arm clean-up and bushings Spridgets 7
B Time to go racing again - seeking clean Spridget Racing 32
T 30 minutes of clean up and much better Triumph 19
T MGB-GT Clean MGBGT cheap on BMW forum MG 5
T How should I clean my diff now that it is out..... Triumph 9
jjbunn Calipers! How to clean and install? Triumph 7
boeingpilot Brake Rotor Clean Up Restoration & Tools 4
RickB To clean old tarnish off replacement fuse box? Spridgets 10
walshja how do you clean Spridgets 5
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
regularman The clean up Spridgets 0
S Battery bay clean up Spridgets 5
C How does one clean a BE steering wheel? Spridgets 4
jjbunn How best to clean up seat rails? Triumph 2
