Choke assembly
Rut
I'm putting my Bugeye dash together and found that I don't have the correct choke cable assembly and knob. I have an assembly from a later MG that's large with a 4 bladed fan and lock on the face. Can anyone help me out?
thanks, Rut
nomad
Don't have a spare stock cable but want to mention that the stock cable does not have a lock on it like the cable you now have. May not look correct but you will appreciate being able to lock the "mixture enrichaner" on while the engine is warming up.
Kurt.
Whitephrog
My spread sheet shows that I have a restored spare. I'll check shortly.
Rut
Rut
Kurt and Ray,
Thanks for the help! I have 2 different style knobs/cables that twist to lock, 1 with the knob in my first post and a T handled assembly that also twists to lock. Kurt, your point about the original non-locking feature doesn't concern me that much, but I may be able to make a hybrid assembly that locks. Ray, I can definitely use your restored spare!
Thanks, Rut
Whitephrog
Found the cable. It's actually new rather than restored.
Rut
Rut
Ray, that's perfect! Please let me know what you want and method of payment.
Thanks, Rut
Also looking for a Bugeye fuel gauge, mine is for a MK2 Sprite.
Whitephrog
My database says that have a spare fuel gauge as well (p/n 2A9069 correct for BE). Will check tomorrow.
dklawson
Out of curiosity, do those early choke cables have the "twist-lock" built in? I was wondering if the similar early MGB cables could be used. I believe early MGB cables have the twist-lock and the simple letter "C" while later ones had the "T" handle profile. Very late ones had that "fan" icon on them as if they were for the heater controls or something.
Whitephrog
No twist lock on the BE cable. In my experience I've never needed that feature.
Rut
Rut
Ray,
I'll be out of town for the next week and have limited access to the forum and email. Please let me know what I owe for the fuel gauge and choke assembly and I think you have my current address. I'll mail/paypal the amount next Friday if that's ok.
Thanks, Rut
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
E T-Series MG TD choke cable MG 2
O Electric choke problem. Jaguar 0
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
S TR4/4A choke linkage Triumph 2
T 100 Choke Modification Austin Healey 5
L Help with electric choke, 1960 AH BT7 Austin Healey 2
R Choke Not Working In Cool Weather Austin Healey 15
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
B BT7 carburetor - choke - fuel questions Austin Healey 5
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
N DCOE double vs. single choke theory Spridgets 11
bighealeysource simple choke question on BN2 Austin Healey 2
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
L 1955 XK140 auto choke "otter" switch Jaguar 1
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
