TR6 Changing TR6 fuel tank sending unit...
Flummoxed
Guys-
My Bentley manual has steered me wrong before. Is the only way to change this to drain tank, and pull it? I guess it seems straightforward that this would have to be the way (due to the location), but maybe there are some tips or shortcuts I'm unaware of. What about access through the filler hose neck area (removed, of course). Although I think the sending unit is the problem, it almost seems easier to at least change the gauge itself (I assume it's a Smith's and I've seen them for sale in Moss).
rcn491
Member
I just finished repairing mine without removing the tank.
I removed the mounting bolts, loosened the filler hose, and slid the tank out about an inch. The sending unit can then be lifted and wiggled out. There is enough slack in the hoses to do this without draining the tank.
F
Flummoxed
Really? And installing it was okay? You can move the float arm enough to slide it in somehow? And you ust loosened the filler hose, didn't remove anything but the bolts? Very valuable info., thanks.
Andy Blackley
I also replaced mine as rcn491 describes. I removed the filler hose and filler cap completely and replaced the hose however. If the screws on the sending unit are not rusted it will come out easily. Don't forget a new gasket.
F
Flummoxed
I assume you are accessing the screws for the sending unit from the "back seat" area (panel removed, of course)? There seems to be more height to allow a tool in there to get the screws out. Pulling the gas tank about an inch out from the trunk seems as though there would not be enough space to access the screws to the sending unit (unless you are pulling it so far out that it is free to unscrew from the top)? Or is there a special tool that allows such a minimum clearance to get in there and uncsrew? Also, I just noticed near the top of my tank about a six by three inch patch, that is very solidly in place and does not leak. However, it does look gerry-rigged and concerns me a little. Has anyone heard of patching a gas tank before? Thanks for all the help.
Andy Blackley
I accessed it from the boot, with the trim panel removed. With the bolts removed the tank tips out far enough to get a screw driver on those screws from the top. On the TR250 there is only the filler hose to be removed. I think on later cars you would have to deal with evap plumbing as well.
Can't help on the patch.
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
SpannerMan TR6 TR6 jack minimum height for changing a tire? Triumph 5
G TR6 Changing floorboards in a TR6 Triumph 8
F TR6 Changing 73 TR6 Water Pump Triumph 0
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 changing lock barrels Austin Healey 7
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
B Changing to Silicone Brake Fluid Spridgets 18
G Changing Horses in Mid Stream.... Triumph 47
T Changing front bolt pattern? Triumph 9
19_again changing right angle drives MG 1
G Changing my Sway Bar Triumph 11
S Fuel Pump, changing ground Spridgets 3
vping Changing from 2 batteries to 1 battery - Why? MG 28
davidk TR6 Changing TR-6 Fan Belt - Need Help! Triumph 11
