Car suddenly started running poorly
scoutll
The car is a 63 Midget with stock 10CG engine except for electric fuel pump..
We were out a few days ago with the Midget. It ran great all day while running around (about 75 miles total). Just a couple of miles from home it suddenly started bogging and making that fuel starved backfiring as if it were running very lean. Barely had the power to keep itself going. I got it home, but it was running very poorly. Idling badly and if you try to give it gas, it shudders and makes that "lean" backfiring. Pull the choke out and it runs better for a while before it bogs. Points, plugs, cap, coil have about 1000 miles on them. I did a little trouble shooting and found that the clear fuel filter under the hood was almost empty.. Ah, says I, it must be the inline filter in the back, between the tank and the pump then.. I changed that out..... no difference. Well, then it must be that old cheap dimestore fuel pump that has been on the car forever. I went to town and bought a Facet pump, put it on....... no difference... I figured I'd ask and see if anyone has any ideas or has run across a sudden thing like this before...
Check the floats and bowls for sediment?
R&R the condenser?
m
JPSmit
sounds like gas. I might get some gas line water remover and throw that in before anything - just to make sure it isn't the fuel itself.
then take it a section at a time.
1. disconnect at carb and run pump to check for flow. If no, or diminished flow, check a section at a time till you are back to the tank. (also run without filter to see if that makes a difference)
2. If flow is fine, time to clean the carb.
there is also a chance it is air - Listening to your description, I had a similar problem and found the manifold nuts had worked loose. The way you can check that is to cover the air intake some as the car is running and see if it improves.
While you are doing easy checks, take a look at the plugs just to confirm they are a good color and not compromised.
let us know
G
I love the simpliciy of points, but hate them because sometimes they'll act like a carb problem. Did you check your contact condition. I'm more likely to say fuel, but check the points just in case.
Gundy
Intake leaks can cause similar symptoms.
You can spray a LITTLE bit of starter fluid at the
mated parts and an idle rise will tell you it's
sucking outside air. A LITTLE spray. That stuff is
VERY flammable.
This is how I check the seal when installing headers or new carbs etc.
It doesn't take much of an intake leak to cause major running problems.
A vacuum gauge will usually show fluctuation at idle when
there is a leak.
jlaird
I would first expect that one of the carbs is not getting fuel. Check the float bowls first to see that they are both full otherwise you have a stuck float valve.
bugimike
I agree with Jack. Check the float bowls first. Sounds like sticky needle valve(s) to me!
scoutll
scoutll
The problem was the front float valve. The chamber was empty. I cleaned it and freed it up and everything worked fine. In the meantime, I discovered that both of the carb floats leak. They have about 1/4 inch of gasoline inside them. Needless to say, they will not work properly that way. Is there an effective way to fix them, or does anyone have some extras they want to sell? These are the plastic type for the AUD73 carbs.
G
Excessive altitude !!!! You live too high up. Don't worry, I've got an easy fix. In about two days, a guy with an enclosed trailer will show up. Simply give him your keys and the problem will be solved. Just come on down whenever you feel like going for a drive. I'll keep 'er loosened up and aired out for ya in the mean time. :driving: I'll need a couple of day to install a door wide enough to fit the car in my house. I wouldn't want to store it outside.
No need to thank me. I don't mind helpin' a fella out. :jester:
JPSmit
I suspect Joe Curto would be your best source for new floats.
https://www.joecurto.com/
jlaird
I agree, I would call Joe.
scoutll
scoutll
kellysguy said:
I still think he needs to send me the car...
I asked Miss Chuff an she said she don't want to go down there. Too many Moccithons or Pythcissins or other such snakes :eeek:. Unfortunately, she has all the standard misconceptions most northern cars have about the south. Hurricados, Himacanes, big spiders, snakes, lizard type things, flamin ants, killer bees..... MONSTER TRUCKS!!!
:shocked: I had to take the TV out of the shop. She saw that Billy the exterminator dude the other day. Heck, just one gander at his mullet and she near emptied her rear differential all over the floor... :cry:
Platinum
She's safe where she is, fer sure. An "added" benefit is that you are geographically situated to take advantage of an extended 'Annual Winter Tear-down' season to do the things we seem never to get to "down here." Endless summer has a downside.
:smirk:
jlaird
Endless summer for the win. No excuse for things not getting done Doc.
Platinum
:lol:
I was ~trying~ to be supportive to Bryan, Jack. :smirk: :jester:
scoutll
scoutll
Doc, I was actually beginning to believe the extended winter propaganda line you were feeding me.... Then Jack had to pipe in. Believe me, I would move farther south, it's just Miss Chuff who's afraid of monster trucks and Billy the Exterminator.... :thumbsup:
Platinum
Oh, bother.
Well.... how's this, then: Come to th' Dar.... err... <span style="font-weight: bold"><span style="font-style: italic">Gulf</span></span> Side. We have nice breezes, endless summer, nice two lane roads inland, it's visitor friendly in the main. Only downside is an occasional oil slick, them pesky fiberglass eating termites and a few mosquitoes large enuff to carry you home and drain ya at their leisure. Nothin' to be concern'd about that a bit of plannin' can't overcome.
...but I do feel obliged to at least <span style="font-style: italic">mention</span> the sodium enhanced rust mites...
:devilgrin: There. That oughta help. :smirk:
Michael Oritt Car dies suddenly Austin Healey 42
A Why is my car making this noise? Other Cars 3
N Wanted Help with car identification Other British Classifieds 2
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
drooartz MGB Any risk rolling car on dry bearings MG 4
mctriumph General TR NEVER start a car with stale gas Triumph 0
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
AngliaGT Today's Car Show Spotted 8
P Where’s the British car? Spotted 4
apbos Help Identify this car chassis Racing 20
mezy some dreamers out there in classic car land Jaguar 8
B How to Get a Proof of Income for a Mortgage or car loan? Other Cars 3
Basil Alfred Hitchcock Frenzy - What car is this? Spotted 6
dougie Use your car as it was meant to be used Austin Healey 15
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
LAW75 Car Trailer Austin Healey 20
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
A General MG 2022 Car Display Geelong MG Car Club MG 2
glemon TR5/TR250 This is The Car Triumph 1
S Well, it is an RWA car Spridgets 2
AngliaGT At Today's British Car Club Meeting Spotted 7
Celtic 77 MGB Car history MG 1
Basil Internet Movie Car Database Other British Cars 0
Basil Hagerty Car Valuation Tool Other British Cars 1
L Can anyone tell me what car this is from please? Other Cars 0
shadowfever Rugby Car Show Spridgets 3
P Unknown British sports car Spotted 7
drooartz Viability of a parts/donor car Spridgets 6
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
Boink Kit Car? Spridgets 7
T Wanted PANTHER J72 or AUSTIN POLICE CAR switches Other British Classifieds 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
drooartz MGB Early tail lights on later car MG 17
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
AngliaGT MGB-GT I Never Thought of an MG as a "Cookie Cutter" Car 'til Now MG 3
T General Tech Car Parts Jumble Sale in Raleigh, NC on June 4, 2022 MG 1
