TR6 Can't leave top down
pdplot
Bronze
I would love to leave my top down all summer but if It's down for more than one day, it takes 3 strong men to get it to close. I never had that problem on any of the other convertibles I've owned in the last 64 years - 4 MGs, a TR3 and a Corvair, plus my son't Fiat Spider and my daughter's Mini. Any other owner have that problem? This was a new top 18 years ago and except for one small tear, still looks like new because the car was always garaged and never driven in the rain or the wintertime. Other than a new top, are there any suggestions? Thanks.
PD
Geo Hahn
Some people lay a new top in the sun to make it easier to install and stretch into position -- problem is that later, when the top is cold, it is very hard to install.
Also, some top material will shrink though the years.
In addition, many of the tops sold are a bit small (I wonder if the made the patterns using original tops that had shrunk.
I'd say leave it off -- top down driving is really the default position for these cars -- and get the 3 strong men (and a sunny day) to put it back on in the Fall.
TR3driver
Great Pumpkin - R.I.P
Oops, sorry, nevermind. I forgot to check the category, thought you were talking about a TR3 top.
titanic
If the problem is pulling the top forward far enough for the pins to align with the holes in the top of the windshield, I have found that it helps to reach in the side window opening and pull the vertical part of the top frame foward while guiding the pin into the hole. As others have mentioned, heat is your friend.
Berry
trrdster2000
pdplt, I found out years ago that the strap is what shrinks the most and have taken the pin out and rolled it up and kept it in the boot and take it out if you need to install.
Wayne
P
pdplot
Bronze
Note to Poolboy - I do have a tonneau cover - it's hanging on my cellar wall. It's good for keeping the summer sun off my black seats. I've burned my butt several times. Now, I just flop up the top but don't latch it when I leave the car out in the sun. And yes - the problem is fitting the pins into the holes, especially when the weather turns cooler in the fall. I've tried boiling water, a hair dryer - nothing works. The Fiat top was easy - just reach back,flip it up and latch it.
glemon
Mine is a little tight, but sounds like it is not as bad as yours, but the same problem, in the hot sun not too bad, on a warm spring or fall day doable, in the winter next to impossible. As mentioned it could be the webbing which you could replace or adjust by drilling out the rivits. I try to leave mine up in the hot sun (all sealed and buttoned up, and I will then even push on the vinyl when it is soft and stretchy to hopefully stretch it out more, and I always store it with the top up in the winter to (hopefully) prevent shrinkage. Luckily it seems to have gotten a little better over the years, maybe it has just stretched normally, or maybe my methods helped a little bit.
P
pdplot
Bronze
I'll check out the straps. meanwhile, I've been leaving the top up but unlatched in the garage. I'm hoping (perhaps in vain) that I'll still be able to button up the top in the fall. Thanks to all.
Gliderman8
Here's one more thing to try-
make sure the snaps are off on both sides just behind the "B" post. Then, reach under the top and separate the Velcro holding the top to the bow. This will let the top stretch a little more.
P
pdplot
Bronze
I leave the snaps off until the top is finally up. The last snap on each side takes real work. As an aside, I read where the tops of the Solstice and Sky are also a PITA to put up - and these are new cars. Future classics?
J TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
Jim_Stevens You know when to leave when... Restoration & Tools 3
GTP1960 TR2/3/3A Dimmer switch mount [ or learn to leave well enough alone] Triumph 14
jfarris TR2/3/3A 56 TR3 - Convert to Neg Ground or Leave As Is Triumph 18
rlich8 TR6 '76 TR6 - De-Smog or Leave? 19k original mile car Triumph 29
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
T Can someone please teach me to leave stuff dirty Triumph 22
memphis BJ8 - Leave ignition key on? Austin Healey 5
T TR2/3/3A Convert TR3 to negative earth or leave it be? Triumph 14
Jim_Gruber Need an opinion - Leave alone or straighten fender Spridgets 29
G I should leave things well alone, I swear Triumph 16
Bruce_B Flywheel -lighten it/aluminum/ or leave it Spridgets 17
Nunyas Can't leave well enough alone... MG 18
6 Seam Sealant: Remove, Replace, Leave Intact? Spridgets 1
Mark_Gibson Opinions on a TR-2 Engine, Rebuild or Leave Alone? Triumph 14
Paul Slice Can not leave well enough alone MG 5
JamesD BJ8 Top Frame Bumpers Austin Healey 4
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
S TR2/3/3A new Robbins top Triumph 11
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
E TR6 TR6 top dash trim paint Triumph 2
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
B TR2/3/3A TR3 Hard Top Triumph 2
C 100/6 BN4 Soft Top Frame Austin Healey 7
KiwiStagguy For Sale Stag Black Mohair New top Cheap Triumph Classifieds 0
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
T TR4/4A Surrey top question Triumph 18
77MidgetMkIV New top and interior-that escalated quickly! Spridgets 9
T TR4/4A Recommendation on top for a late TR4A Triumph 8
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
J TR6 Hardtop/Soft Top Installation Triumph 2
T Interior Door Panel and Top Rail Austin Healey 3
J TR6 Top End Chatter Triumph 11
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
W TR6 Tr6 soft top lnstall Triumph 5
J Top Trunnion Bushing Fit Austin Healey 9
dbenichou289 TR2/3/3A top frame bracket Triumph 7
A TR2/3/3A TR3-A replacement top Triumph 7
A BN4 Hard Top Austin Healey 23
S For Sale Triumph TR-3 Convertible Top Bows Triumph Classifieds 1
Healey Nut Good hard top on flea bay Austin Healey 6
G 1960 3000 BN7 Top Help Austin Healey 0
M 1966 BJ8 Top Austin Healey 1
W Spitfire Hard Top rubber Triumph 5
Marvin Gruber BJ7 Top Installation Austin Healey 1
