TypeRboy
I'm starting to hate this BDA.. The problems I've had fitting what should have been a fairly straight swap into the Cortina have been very depressing. I am finally at the point of fire up, but I am getting no oil flow from the sump to the pump. I checked the oil pump again, inc the bypass valve, and it's fine. I even used the pump off the Cortina block, cause I know it works. The pump simply won't draw oil from the pickup.
I have primed it to death, and spun the motor over at about 500 rpm for long enough to tell nothing is happening. I have 5 liters of oil in the pan, which should be too much.. Next the motor comes out for a pickup inspection ( like maybe it fell off?? )but everything was fine there on assembly. Is there anything i don't know about that could cause blockage between the pump and the sump pickup? Anybody else ever have problems getting oil flow in a new Ford Kent motor ( lotus twink, english ford, Cosworth BDA, they are all basically the same oiling wise..)
Desperate and dumbfounded in Abbotsford /ubbthreads/images/graemlins/cryin.gif
