Can a Bugeye fuel tank sender be restored?
ncbugeye
First let me ask a question...
A Bugeye sender is just a resistor, right? So the fuel gauge is just an ohm-meter, passing its current to the chassis through the wiring in the sender unit.
If I connect an actual ohm-meter between the single terminal and the case of the sender unit, I'd expect to see the needle move as I slide the float backwards and forwards. Since I see a dead short all the time, either my ohm-meter is bad, or the sender unit is dead.
Can they be rewired, or is it not worth it? Moss quotes $49.95 to replace it, which doesn't sound unreasonable but if possible I'd prefer to restore.
Opinions?
regularman
I doubt you have a dead short, have you checked all the wiring? If worst comes to worst, send me the sender and the guage and I will check and calibrate it for you. I would drop the tank and check it there. You might have a pinched wire. those fuel tank senders are a wire wound resister with a slider on it. They are pretty tough and To be shorted don't sound right.
ncbugeye
ncbugeye
I have the tank off and the sender removed from the tank already. Using an ohm-meter, the sender itself seems to be a dead short at any position of the float unit.
Methinks before I make a rash decision I will go get a new ohm-meter, this one is ancient, I have had it at least 25 years, it was cheap when I bought it, and it may be the problem.
How many ohms should the sender unit resistor be?
jlaird
Guys, I would point out that Kim is the resident expert on fuel gages and senders.
If he can not make em work, oh wait he always makes em work.
spritenut
90% of the dead senders I have taken apart have that thin wire fried off near the terminal. I have successfully reattached that wire and the sender worked again.
Well alot of them worked again but not all.
Hey, if it's broke, I'll at leaast try to fix it before I throw it out.
ncbugeye
ncbugeye
Frank,
Thanks for that reassurance. I had the top plate off and looked at it, it is very clean inside and I didn't see anything broken, but tomorrow in the sunlight I will take another very close look at it, or maybe better still have my teenage son look at it as my eyes aren't as good as they were.
For reference I would like to know what the resistance should be, and at which end of the float's travel I should expect to find it.
Sarastro
This is pretty much what I would expect. In most sender failures, the problem is an open circuit, not a short. Of course, anything is possible, but if you see a short, it's probably something simple like bad insulation allowing the wire to contact the case.
If you are using a digital multimeter, be sure the battery is OK, of course, but if the display shows an indication, the battery's almost certainly OK. Touch the probes together, you should get zero ohms; separate them, and you should get an infinite indication. If this happens, I wouldn't suspect the meter.
Be sure you have the meter on the right scale--if it is on a high scale, the relatively low sensor resistance might just read zero.
As for the resistance--I made some measurements of this at one point, but I can't seem to find them. If I remember correctly, the sensor is about 65 ohms, maximum, but don't take this as a certainty. It should be on that order, though; if you see 10,000 ohms or 1 ohm, obviously something is wrong.
regularman
ncbugeye said:
Frank,
It should vary between 0 ohms and 70 ohms or there abouts.
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
drooartz Later fuel tank in a Bugeye Spridgets 11
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
athenssprite Fuel tank - 1960 Bugeye Spridgets 12
ncbugeye Bugeye Fuel Tank Spridgets 8
ncbugeye Need immediate help with Bugeye fuel tank Spridgets 10
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
I Bugeye fuel fitting Spridgets 3
I Bugeye fuel pump help Spridgets 2
Rut Bugeye fuel gauge Spridgets 14
BlueMax Bugeye Fuel Gauge Spridgets 3
P Herko kd8016 fuel pump in bugeye??? Spridgets 5
P Bugeye fuel line? Spridgets 3
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
ncbugeye Push SU fuel pump in Bugeye Spridgets 8
drooartz eBay Bugeye fuel tanks, recent experience? Spridgets 8
Glen_B Bugeye Fuel Injection Spridgets 4
msoylemez Bugeye Fuel Gauge Spridgets 3
P Electric Fuel Pump for Bugeye??? Spridgets 12
B Electric fuel pump for a bugeye - Questions. Spridgets 13
B Bugeye Fuel Pump Austin Healey 1
G Bugeye fuel pump Austin Healey 4
R bugeye tail lights Spridgets 4
R bugeye side lights. Spridgets 0
R six bladed fan - bugeye Spridgets 0
B Bugeye Electrical Diagram Spridgets 0
drooartz Bugeye fits on the lift! Spridgets 6
drooartz Hoovie buys a Bugeye Spridgets 14
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
R bugeye slip covers Spridgets 1
W New Yellow Bugeye Spridgets 5
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
pbraun Bugeye tonneau pattern Spridgets 1
J Bugeye seats wanted... Spridgets Classified 0
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 13
longbridgehealey Bugeye combination switch Spridgets 2
bugedd Wanted: Bugeye cockpit surrounds Spridgets Classified 7
Ljohns Lots of Bugeye Parts - CHEAP Spridgets Classified 8
longbridgehealey Bugeye ignition switch Spridgets 4
R Bugeye Medallion Spridgets Classified 4
T Bugeye seat recline Spridgets 5
longbridgehealey Bugeye dash Spridgets 6
S Bugeye Windshield Seal Austin Healey 1
Spritey Bugeye Build Video Austin Healey 2
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Which is the correct door knob for a 59 bugeye? Spridgets 3
R Bugeye nose Spridgets 6
