Bugeye speedo/tach in a MKIV?
Atrus
I really like the face on the bugeye speedo and tach - the silver disc in the middle. I know the tach is mechanical. Any way to retro (reliably) both of these into an MKIV with a 1275? I am thinking no, but thought I'd ask anyway.
jlaird
There is, thread around here someplace and yep the pointers are interchangeable to my knowledge.
bugimike
Jack, I have taken the guts out of a newer speedo and installed them into an old Bugeye case & face. worked great! Did have to fiddle with the odometer openings asthe newer unit has more digits. Did it slow and careful and it looks great and works well too! As far as the Tach, I used and electronic unit out of a Fiat. It doesn't match, but works real well. Atrus, the newer guages are a smaller diameter than the Bugeye (3" vs. 4") which would require some dash surgery if possible!
Mike
59 Bugeye
69 Sprite
jlaird
There are instructions here someplace to convert an electrical tac into a mech case etc etc. Same case and face etc is used, just changes the inards.
Sarastro
The tach internals (I haven't dug into the speedometer yet, good luck to my speedometer!) are held to the face by two small screws. That's all. If you install the internals of some other tachometer into a bugeye case and face, you probably will have to drill new holes for the screws and figure out some way to fill the old holes (they're small). One potential problem is the shape of the face--it might happen that those screw holes, on the tach internals that you put in the bugeye case, will end up on a curved surface of the bugeye face and that will make mounting it much more difficult. This might be especially likely with the speedometer. You will have to cut a hole in the tach case for the electrical connections as well. But that's all I can think of. I should be straightforward to do all this with ordinary hand tools. Just check and measure everything so you don't do a lot of cutting and then find that something won't fit.
Have fun!
jlaird
Use the old screws to fill the old holes, a drop of somthing on the back will hold em, cut to a shorter length?
Sarastro
That probably would work. Or, just fill the holes with epoxy and color it in with a felt-tip marker. They're so small you could probably just ignore them and no one would notice.
jlaird
Yep. Expect you are correct. Only a few of us would even know it was wrong. Go for it.
Team_Sprite Bugeye Luggage Rack, Speedo & Tach Jewell Inset Spridgets 30
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
M Bugeye speedo cable Spridgets 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 2
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
