Brake warning light stays on - help please
ichthos
The brake warning light came on about a year after I totally redid the braking system on my TR6. The only thing I didn't touch at the time was the PDWA switch, which I just now rebuilt. After reinstalling the PDWA valve and bleeding the brakes, the brake warning light still stays on. I checked the brakes and there are no leaks. Any thoughts on what I am missing here?
Kevin
TR4nut
Do you have the PDWA valve centralized? When you bleed the brakes, you need to be careful otherwise that switch will kick in. This may not be the best way to diagnose, but I'd bleed again, crack the front or back side and push on the brake - if you've picked the correct end to start from, the shuttle in the PDWA will move over and the light will go out. If not, bleed the other end and see if you can get it to kick over.
hondo402000
well easiest way to find out is to un plug the wire going to the switch, if the light goes out its switch related, or the PDWA has shifted, since the circuit is just a grounding circuit, if you unplug the wire and the light still stays on the circuit is grounding somewhere
Hondo
hondo402000
and ps when you turn the IG on the light is suppose to light up as a safety so you know the bulb is not burned out but upon starting the car the light goes out, if it stays on while the car is running then check as I stated above
Hondo
Platinum
Can't recall but: is there a switch at the handbrake lever too?
Gliderman8
I beleive the handbrake switch was only on later cars, but you might check to see if a PO installed one as doc suggests.
DNK
From Work???... you get a summer job?
Kevin my guess is you got the wire grounded somewhere. That's how it works
I
ichthos
Don, I either have meetings during the summer or have to go to school during that time. Today it was another exciting meeting.
So, I took the wire off of the switch, and the brake warning sign still stays on. That rules out the switch (for now), but how do I find where it is grounding? I noticed it after the new engine was put in.
Kevin
DNK
Your gonna have to trace that wire . Unplug it from the light and then ...
Geez, I don't know. Run a new one??
Gliderman8
Kevin- Did you check to see if there is a emergency brake switch as doc suggested? It is possible that someone added this switch to the handbrake... just a thought.
poolboy
If the "Brake" light is on and it's not because the wire to the PDWA is grounded, then look to the Oil Pressure switch..The PDWA/BRAKE light circuit and the Oil Pressure warning light are related, electrically speaking.
If the OP switch grounds either due to low OP or a faulty switch, the "BRAKE" light will glow and the OP warning light will glow, although that light is hard to see lit in daylight..
However if the OP switch is working correctly and not grounded, a grounding of the PDWA wire will only illuminate the "BRAKE" light.
TR3driver
Great Pumpkin - R.I.P
Don't mean to be picky, Kevin, but it would help if you would tell us what year TR6. They aren't all wired the same.
Assuming you have one of the ones that uses the oil pressure switch for the "bulb test" function, my next step would be to pull the wire(s) off the oil pressure switch. Especially since the problem showed up after an engine rebuild.
If no joy there, I'd try to do a visual on as much of the harness as you can; then maybe try the compass trick. Or just run a bunch of current through the short and feel around for where it gets hot.
TR3driver
DNK said:
He did pull it Randall
Err, he said "the" switch. Was that the oil pressure switch, or the PDWA switch? If he pulled both wires off, he should have said so ...
I
ichthos
Hi guys - yes it is a 69. It does not have a hand brake switch. All I have done so far is remove the wire to the PDWA switch and the brake warning light still stayed on. As suggested I pulled the wire off of the oil pressure switch and the brake light doesn't come on even when I first start the engine now. I didn't realize the two were related in any way. I am still confused. The oil pressure switch is fairly new, but does this mean the oil pressure switch is bad?
Kevin
TR3driver
It's kind of a strange system, but the oil pressure switch provides a "bulb test" function for the brake warning light.
Assuming the oil pressure gauge shows pressure, then a bad switch is the most likely explanation. A 69 would have the single-terminal switch, so no question of the wires being installed wrong.
I
ichthos
My oil pressure gauge is working and shows good oil pressure. I will swap out one of my old oil pressure switches for my new one and see what happens.
Kevin
poolboy
When you get a little extra cash, Kevin, you really should get Dan Master's "Electrical Maintenance Handbook" for the Triumph TR250-TR6
I don;t know how I got along without it for the first year I owned a TR6.
It's written in plain language with diagrams or photos of what he's discussing.
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
7 brake warning light coming on Other Cars 5
Gerry M TR6 Brake Warning Light Stays On Triumph 3
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
J MGB Question on the brake warning light for 78 MGB MG 6
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
I TR6 TR6 Brake line, hazard warning light not working. Triumph 3
Woodie Brake warning light Spridgets 15
Musicman Brake Warning Light Triumph 5
certifiedcarnut 948 front brake shoes warning Spridgets 5
Morris Brake Warning Switch Assembly Spridgets 10
angelfj1 BRAKE CLEANER - PLEASE READ THIS SAFETY WARNING Restoration & Tools 13
angelfj1 Silicone Brake Fluid Warning??? Restoration & Tools 3
angelfj1 Silicone Brake Fluid Warning??? Triumph 26
A Brake warning switch has a Ford part# --$20 Triumph 7
jcatnite Brake Failure Warning Switch Spridgets 16
jjbunn T-Series Brake Pressure Warning Switch MG 10
weewillie brake pressure warning lamp Spridgets 12
Woodie brake warning switch Spridgets 2
jerrybny Brake Warning Lite switch Triumph 1
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
