Brake Failure swtich location
jeff3113
If it's like my 1975 TR6 it should be a foot or so below the brake master cylinder. Follow the brake lines from the master cylinder. Look for a brass fitting where the brake lines meet up with a 2 wire connector from the harness.
good luck,
Jeff
G Brake Light Switch Failure Austin Healey 24
KVH General Tech Brake Failure--The Line Split Triumph 19
G Brake Booster Failure Symptoms Austin Healey 3
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
S How to test a Brake Pressure Failure Switch Triumph 7
X T-Series Brake pressure failure switch MG 4
X T-Series Brake pressure failure switch MG 3
Brosky Brake Adjuster Failure Pictures Triumph 8
H brake light failure Austin Healey 20
T Crypt Car Brake Failure Triumph 64
jcatnite Brake Failure Warning Switch Spridgets 16
Woodie brake pressure failure switch Spridgets 15
ecurie_ecosse Brake pressure failure switch. Spridgets 8
S Brake Failure Triumph 6
G Pluging the brake failure switch Spridgets 2
J T-Series brake failure switch problem MG 5
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
