BRAKE CLEANER - PLEASE READ THIS SAFETY WARNING
angelfj1
just read this on the TR Register UK Site.
wow - this poor soul almost died.
please use all solvents containing tetra-chloro-ethylene (127-18-4) with extreme caution :nonono:
WARNING
TRMark
Bronze
Wow! Thank you for posting this. I made a few copies and gave them to friends.
Brosky
Wow is right!!
That is scary and I've been around all of this stuff all my life and never knew it could be that bad.
BabaKahawa
Good read, Scary stuff, You might want to post this on the other forums.
Thanks
Eric
There are non-chlorinated brake cleaners commonly available (contain hexane), which are much safer in all respects except flammability.
Banjo
As far as I know, most all Brake parts cleaners now sold in the US are non-clorinated. Still, that's an inportant thing to know about. Thanks for the post.
I know I have a few cans of "the good stuff" in my cabinet in the shop. I'm probably ok since I dont have argon in any form in my shop
LarryK
Remember to use safety when you use any of the compounds and chemicals used in any circumstance. We are all guilty of miss use of compounds not realizing how dangerous it can be. You are on a job and close to finishing and run out of a chemical that is right for the job, but in a hurry or not wanting to leave and get the right stuff, you use what you have, luckily you got it done. It only takes once to get to you or a loved one in the vicinity of your project. It does not just mean garage stuff, but household too. Use your collective learnings and use the proper stuff and you'll always live to enjoy that precious car or family the rest of your life. It's just like getting under a car without jackstands or lifts and depending on the jack to hold it. THINK FIRST, THEN DO IT RIGHT! for you and your family.
DougF
I sell four different brake cleaners, three non chlorinated and one with tetra-chloro-ethylene. Looking at the MSDS sheets for each I found that all of them can kill you if not used properly. Don't allow high concentrations of fumes to accumulate.
Drinking the stuff isn't healthy either.
tony barnhill
Great Pumpkin - R.I.P
"Drinking the stuff isn't healthy either."
Anybody who drinks the stuff shouldn't be allowed to contribute to the gene pool...let him drink it & suffer the consequences.
Platinum
Amen, Tony! Doug *has* to point out th' obvious... Same as: "WARNING: Hot Coffee!" an' all that. :smirk:
Frankly (or Johnly), I found it funny. :wink:
How do ya keep kids from huffin' glue? Or playin' the "Choking Game"?
Tellin' 'em it'll KILL 'em doesn't seem to work. Th' Bad News is: those who've tried it and only HALF died are now VETTED!! :devilgrin:
...oh I'm gonna SOOOOO pay fer that... :shocked:
tony barnhill
You hit the nail on its head - Tellin' 'em it'll LILL 'em doesn't seem to work.
& the results of studies with white mice in a lab don't mean squat to 'em also!
They have to see a friend die from whatever before it dawns on them that something is dangerous.
Platinum
"BILLY BOB!!! Hol' my beer! Watch THIS!!!"
:devilgrin:
JPSmit
:devilgrin:
Most frequent last words of rednecks :lol:
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
A Brake Master Cylinder Freeplay Austin Healey 11
T TR2/3/3A TR3A Disk Brake Question Triumph 10
