100DashSix
In the process of changing the front brake pads I came across the following step, as described in the Haynes manual: "Pull out the pads...remove the cap from the master cylinder...and press the caliper pistons right in."
As I try to push the pistons in, there is absolutely no movement--on either piston or either side of the car. Are they frozen up? Is there a trick to pushing them in so that I can fit new pads?
Advance Auto and Napa both have them for ~$65 each. I suppose it could've been worse..
Just for fun, here's a picture:
