Brake and Fuel Pipes
Colin8
On my '66 Sprite, the brake line goes thru the tunnel, but the fuel line goes on the bottom, alongside the right rail.
Colin8
Here's a couple more pics:
Here's one final picture of how the original lines were routed before I removed them. I've heard some people say their brake lines run under the car. Perhaps some models did, but I believe the idea was to keep the fuel line external, in case of damage it would leak on the road. But the brake line ran thru the tunnel to protect if from damage that might cause loss of brakes.
HAN8L1965
On the 65 the brake line runs inside the tunnel to the rear and the fuel line attaches to the rail that runs underneath the car There are clips in the rail that runs along the side of the tunnel. the fuel line clips to that.
Mark
spritenut
Brake lines did not run inside the tunnel until 1968 when they went to the dual master cylinder.
My 67 has the lines under the floor on the frame stiffener along with the gas pipe.
HAN8L1965
I have to disagree as I removed the original brake lines from my 65 and one line ran front to rear through the tunnel,my car is a HAN8. It was attached to the inside wall of the tunnel with clips one on the right side before the shifter and the other clip is across from the E Brake handle.
Mark
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
J TR2/3/3A replace brake and fuel lines? Triumph 4
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
J BN6 / Smash my fuel and brake lines.. Austin Healey 5
T Flushing brake and fuel lines Triumph 3
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
MCNX_BFF Wedge TR7 brake fluid leak--bonus: fuel leak, too! Triumph 9
drooartz Brake and fuel lines in Spridgets 2
C Fuel and brake lines. Triumph 0
Tinkerman Brake and Fuel Lines TR 3 Triumph 6
OZ_BN1 BN1 fuel, brake and wiring along chassis rails Austin Healey 7
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
djk Prebent brake/fuel lines Spridgets 6
Bruce_B Source for brake line/fuel line clips Spridgets 7
ronzet Keeping the brake and fuel lines nice and bright Austin Healey 3
K Fuel Vapor in brake booster?? Austin Healey 2
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
