BN1 rear wheel hub
zblu
RobertM
axle or hub extension? left or right side?
if its the hub extension than these can be got new from suppliers
Keoke
Hi Bob What is wrong with the hub you have if you have one? ?--Keoke
vette
My question would be the same as Keoke's. But if you must have one, Try Healey Surgeon's in Maryland. It never ceases to amaze me the stuff they have.
R
RobertM
Member
The studs have come out and been stripped. I tried Healey Surgeons and they said the one they have is not very good. I am hoping someone might have one in their parts bin they might be ready to part with.
Bob
Keoke
Hi Bob, I believe there are repair type studs available which a machine shop can press in for you. However, You might give British car specialties a call and see if they can service you.--Keoke
healeynut
Robert -
SC Parts in the UK sells a replacement hub for 199# (sc part no 321 588), but it uses the same old studs so will be prone to failure eventually.
If you are willing to wait 6 months or so, I am in the process of machining and producing new completely redesigned hubs which will make the old BN1 axle better and more reliable than the later axles which are heavier. But you will have to be patient with me, I am very busy at work these days.
Good Luck!
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
catfood BN1 Rear Axle drain plug. Austin Healey 7
catfood Rear hubs on a BN1 Austin Healey 4
Dougal BN1 rear hub markings Austin Healey 3
I BN1 Rear Suspension Austin Healey 0
T BN1 Rear Bump Stops Austin Healey 10
Z Early BN1 Rear Shock Bolt Dimensions Austin Healey 10
bighealeysource Rear brakes on BN1 - HELP !!! Austin Healey 12
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
F BN1 Rear Shroud Rivets Austin Healey 8
Michael Oritt BN1 rear leaf springs Austin Healey 4
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
