BN1 / BN2 with a serious identity problem
Peconga
Greetings!
I recently acquired a heavily modified BN1 or BN2 series vehicle with a serious identity problem. It presently sports a state-issued VIN plate on the firewall, which of course has no relationship to the original chassis number. My goal is to establish the original series and chassis number to use with a repro chassis ID plate from Moss Motors, in order to re-register it with my state DMV under the proper VIN.
So far, the only identifying number I have been able to locate is the body number "3490" on the underside of all three pieces of aluminum cockpit trim. Without going into the depressing details, most of the usual clues (engine, transmission, firewall, front brake drums, rear hubs) that would even serve to identify the series (BN1 vs BN2) are missing or altered.
So, any suggestions from the experts out there?
Thanks in advance for your help!
-Peconga in Idaho
Dave Russell
Yoda - R.I.P
Hi & welcome to the forum,
From my limited information, body #3397 was built in May, 1954. Body #3800 was built in June, 1954. Your #3490 is somewhere in between. The first BN2 came out Aug. 1955 so your car is definitely a BN1, or at least was at one time.
You can go here, Heritage Trust in the UK, & for about $60 they will issue a certificate showing the original numbers, dates, colors, etc. Be sure to tell them that you only have the body number. They should be able to search & fill in the rest.
https://secure-site-server.co.uk/~heritage/archive/certificate/certificate+order+form.htm
Good luck,
G BN1/BN2 Sidescreens Austin Healey 0
J 100 bn1/bn2 id Austin Healey 26
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
F BN1 vs Bn2 gear box Austin Healey 23
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
roscoe BN1/BN2 Alternator Conversion Austin Healey 7
A Sidecurtains for BN1 OR BN2 Austin Healey 1
T BN1 / BN2 Top Installation Austin Healey 3
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
F BN1/BN2 Clutch linkage Austin Healey 4
Vineyarder BN1 BN2 Transmission Question, Returning member Austin Healey 0
F BN1 or BN2 for sale in Europe? Austin Healey 3
ShawnC_at_Moss BN1, BN2 Carb Bodies with shafts Austin Healey 0
bighealeysource Anyone ever mount a side exhaust on a BN1 or BN2 Austin Healey 16
T BN1 / BN2 Horns Austin Healey 2
Frankenhealey BN1 or BN2 Hood? Austin Healey 3
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
T BN1 3 Speed to BN2 4 Speed Austin Healey 15
timbn2 are these from a BN1/BN2 by chance...? Austin Healey 20
AH100M BN1 and BN2 two-tone Austin Healey 2
roscoe BN1/BN2 windshield Austin Healey 1
1 100-4 BN1/BN2 Drivetrain wanted Austin Healey 0
A bn1-bn2 recognition Austin Healey 9
jtb55 Conversion of front brakes from BN1 to Bn2 Austin Healey 9
I Austin-Healey BN1 Parts List Austin Healey 1
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
