BN-7 Price
Vaark01
Hi,
I found a 1959 BN-7 in excellent condition--mechanically and cosmetically. The only thing I would have to fix is a very small dent behind the headlight. No biggie.
I have no idea what a fair price would be and would really appreciate your advice.
Owner is asking $50K and said to make an offer.
Thanks.
Paul
Johnny
I would think for 50 grand there would be no damage whatsoever anywhere. Make sure you drive it to verify transmission shifts in all gears and the overdrive works.
nevets
50 large isn't crazy for a BN7 but I'd expect the car to be top notch. Not sure about that dent? Will it require paint? I'd make that a bargaining chip for sure.
V
Vaark01
Dent will require repaint. Transmission shifts fine, but owner said not to use first gear due to ratios?
Legal Bill
No offense intended but what does excellent mean? Was it restored by a top restorer within the past two years?
V
Vaark01
Owner said it took several years to restore. Not a nut and but job, but it does look very nice.
TimK
If it was done professionally it might be worth it. I'd probably sell mine for $30,000. It's an older restoration, with a professional paint and body work, but I did the interior. The engine compartment is mostly original.
This is the in process (not frame off, but all steel panels removed):
V
Vaark01
Tim,
Your car looks great. The one I'm interested in is Healey Blue with a blue interior. I am told the car was restored professionlly, but is not a nut and bolt job. The engine compartment was also painted. Work was done several years ago. Engine was not detailed. Car has high-torque starter, electronic ignition, stainless steel exhaust, painted wire wheels, new top, tonneau and side curtains.
When I drove it it ran well. It does pull to the right and the owner said not to use 1st gear due to ratio. He said he has a part to change the ratio, but will give it to new owner.
That's about all I know about it. I am told the value ranges between $31K and $55.8K.
Paul
mjobrien
Paul,
Might ask the local Healey or British car shop of your choice to do a mechanical review for you. If the seller is not hiding anything they will not object. Knowing about any frame damage and overall chassis integrity is critical in these older cars.
A few recent autions to reference off of;
57 100-6 $55K - Frame off recent restoration
58 100-6 $66K - Famous restoroation shop
61 BT7 $55K - 300 miles new from a recent restoration
Hope that helps and best of luck!
Michael.
V
Vaark01
Michael,
Thanks for the very helpful information. I think I'll have the owner take it to a Healey shop near here for a thorough evaluation.
Merry Christmas.
Paul
rjc157
hi all merry xmas thats alot of money there's a couple of cars on ebay now that look nice that are alot less if you want alittle advice get a local club member to look at the car ,when you get the bug to get into a healey anything looks good then you find out whats wrong ,you have to know what you want out of the car just a driver or concours .original parts are hard to find now so if something is missing it could cost alot and for 50 grand i think the car has to be near perfect because these so called restorers are way over priced their cost is more than the cars are worth good luck
V
Vaark01
Thanks to everyone for the excellent advice. The owner is 80 years old and is a member of the local Healey club. He has owned the car since '91 ans said it took 10 years to restore.
I'll call him on Monday and ask him to take it to a local British repair shop that has done prior work on the car and ask them to do a compete inspection.
I am also looking at a '60 BN-7 that is all original. It will need a complete paint job, but has no rust.
Paul
rjc157
not a bn7 fan but 50 grand is still alot of money if you can get an original that only needs paint depending on price might not be that bad a deal , you could prob get a really good paint job for around 5-7 grand as long as there isn't any rust
Johnny
Paul, I just sold my '60 BN7 this year and got $42 for it. It was a total resto, frame off etc. etc.
How about posting some photos either here on the forum or in a separate website where we can view the car for a more rational evaluation.
BlueRidge1
Probably he means the rear end gear ratio is low and 1st gear is not really needed and maybe for the fix he has one of the Lempert 354 rear ends available. Just a guess but that would be a valueuable piece if that is the case.
BR1
Or, it could mean that 1st is so badly worn (usually the smallest cog on the laygear) that it pops out with a BANG (unless you hold it in). Second (2nd) gear has plenty of oomph to start out in, and lots of owners ignore 1st gear anyway. I made a trip once where the trans got stuck in 4th gear, and took off numerous times in the course of several hundred miles (Atlanta, GA to Spring Hill, FL) in 4th, including rush-hour downtown Tallahassee.
Pulling to the right can be as simple as the tire pressure too low on that side, suspension alignment (which has precious little adjustability) or a bent chassis or suspension component.
As much as I love the 2-seaters, $50k should be reserved for a perfect, no stories car. Really flawless.
You never stated, or I missed it, as to what you intend to do with the car. If it's to be a driver/weekend cruise nights type car, or if you're intending to pursue an upper scale concours type event(s). This can make a tremendous difference.
Personally, I'd be looking for a car in a lower price brkt (the BN7 you mention needing paint, for example) so that you can see the condition of the car, underneath the gloss.
In any case, good luck, and be sure to stay with us.
If you want your pictures posted up here, you can send them to me too (I have somewhat of a reputation for visual images...).
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
S Price check on TR3A valve cover Triumph Classifieds 0
G TR2/3/3A Valvoline VR1 price Triumph 3
S TR4/4A Fair price for a crankshaft? Triumph 2
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
Morris Price drop Spridgets 1
Bmekosh TR6 Fair price for this car? Triumph 16
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
W At this price..... Spridgets 3
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
jlaird Miss Agatha has a new price Spridgets 45
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
PAUL161 General MG Automotive Paint Price! MG 13
1 Price for original 57 100-6? Austin Healey 22
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
W Good price on Pacesetter Monza Muffler Spridgets 0
sqbsprite What will be the real price? Spridgets 11
B Hard Top Price Guestimate Spridgets 1
J Help me price my Bugeye? Spridgets 37
PAUL161 T-Series Engine rebuilds going up in price! MG 14
Jim_Gruber BE Bonnets - OMG the price Spridgets 5
J TR6 Is This a Fair Price for TR-6? Triumph 25
BoyRacer BN2 bellhousing - how rare - price? Austin Healey 2
G [Price] King Midget ? Spridgets 12
K Reasonable price for a Morris Minor project car? Other British Cars 4
HCE What is a fair price for a ’69 XKE? Jaguar 19
aeronca65t Replica Price Lotus 3
C What is a fair price for a Caterham? Other British Cars 2
Rut Fair price for a Midget? Spridgets 10
M Healey 3000 Mild Steel Exhaust good price Source Austin Healey 2
D TR6 TR-6 Steel Hardtop -- fair price? Triumph 4
G Fair price on O/D switch and knob? Triumph 5
CZ_Dave Yippeeee 1/2 price day at MG 0
dougie Clapped-out race car....record price? Austin Healey 3
W The price on this bonnet..... Spridgets 9
W What's a realistic price.... Spridgets 14
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
N Hate to price parts? Triumph 4
Tinkerman 1975 MOSS price sheet Triumph 9
Team_Sprite Isetta as prize on 1957 "Price Is Right" footage Other Cars 0
Gray_Cat The Price is Right... Spridgets 1
P 59 bugeye price Spridgets 12
P 59 bugeye price Austin Healey 5
V 1962 BN7 Price Austin Healey 4
G TR6 Good looking TR 6 with good price Triumph 3
G What's a good price on an O/D tranny?? MG 6
