Bleeding slave cylinder on BJ 8
BJ8Healeys
It's difficult and a pain no matter how you do it. Removing the fiberglass gearbox cover and all that goes with that is not my favorite job, but at least it allows access to the bleeder. Not removing the cover means getting under the car and removing the two attach bolts for the slave. The upper one is a real nightmare.
I just went through this a couple months ago after rebuilding the brake and clutch masters. While I had the slave hanging down under the car, I decided to order one of Doug Reid's slave bleeder extensions. This allows bleeding the slave from the engine bay. I believe it was about 40 bucks with shipping. A friend and I once bled his clutch by the side of the road in about 5 minutes with his extension. More info here: https://www.vintage-sportscar-touring.ca/technical/bleeder.html
windrose
Does anyone have a good way to o this. The older I get the harder it is to get to it!
thanks
Yes, I hated this too. My solution was to cut a hole in the footwell side panel to gain access that will accept the same rubber plug as used for the transmission cover.
I did it during my restoration but you could probably do it with a jig saw once you pull up the carpet. I am installing a carpet piece over the plug with snaps to gain access when needed.
Can send a pic if you need one.
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
I Tips for bleeding Bugeye slave cylinder? Spridgets 12
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Lin Slave Cylinder Bleeding Austin Healey 18
RickB MGB Trouble bleeding new clutch MC & slave MG 6
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
mgedit Bench Bleeding Master and Slave Cylinders Triumph 5
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
nevets brake bleeding Austin Healey 13
C Bleeding the hydraulic clutch Spridgets 6
vickxxx T-Series Brake bleeding MG TD MG 10
Jim_Gruber Brakes and Bleeding Spridgets 16
H bleeding the clutch and not running Austin Healey 17
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
mgedit TR2/3/3A Bleeding Lockheed Master Triumph 7
R General Tech One Person Brake Bleeding with a Mityvac Triumph 12
W Looking for a pressure bleeding system Jaguar 3
Simmo Series 3 E Type Brake Bleeding Jaguar 2
jlaird Brake and Clutch bleeding Spridgets 7
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
N Need Brake Bleeding Help Spridgets 25
T Spitfire Bleeding brakes Triumph 6
J TR2/3/3A Brake Bleeding problem on a TR3A Triumph 19
B Bleeding BJ7 brakes Austin Healey 9
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
nevets Question about brake bleeding Austin Healey 13
RickB New clutch master - the expected bleeding nightmare has arrived Spridgets 16
RichBall Observations and impressions for bleeding the 1500 clutch system Spridgets 5
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
