There's been a lot of chatter on the Healey emailer list about dual master cylinder brake systems so I feel entitled to ask a question even if my particular problem is not Healey-related:
My Elva has a Tilton dual cylinder set up with drums all around, leading and trailing wheel cylinders on the front axle and single on the rear. Tilton in its instructions says: "If the vehicle has a dual master cylinder brake system then both systems must be bled simultaneously."
How do I do that? Must there be three people involved, one stamping on the brake with two others, one at each wheel, cracking bleed nuts "Simultaneously"? And what to do on the front wheels where there are two cylinders? Must each person wield two wrenches so that all four cylinders are opened, then closed during the time the assistant in the car is stepping on the pedal?
I feel I am missing something and will appreciate your experience.
Hi Guest!
