Black sparkplugs
G
Hey guys,
As of late, seems that all six of my plugs are black and sooty, not really wet, just carboned over. I have leaned out the ZS's (all three), changed to a set of low resistance plug wires, running Sport Coil. Points are ok. Stock fuel pump. Timing is good (8 degrees BTDC, centrifugal advance). Any suggestions on getting these things to tan out. Seems they were nice and tan in the past. No smoke out of the exhausts, although they are nice and sooty as well. Perplexed.....
Bill
Dave Russell
Yoda - R.I.P
Bill,
The first thing to verify is that the plugs are the correct heat range for your engine. If they are, things are still too rich.
piman
Hello Bill,
a couple of obvious points, air filter clear, choke coming off properly? The other point is what was the engine doing prior to removing the plugs?. You may want to do checks after different modes of running, i.e. idle, cruise and full throttle. Another check is the colour of the exhaust tail pipe, a car tuned fo economy will have a light grey colour although if for power then it will probably be black so this is not so useful.
Alec
PS. You might like to check your valve clearances also.
G
I switched my plug wires from "High Performance" 8mm wires to stock-style (NAPA) low resistance 7mm wires and now have nice tanish-white plug tips. Too much resistance with the Lucas Sport Coil? Go figure.
Bill
Geo Hahn
Glad you found the problem. I'm not sure what 'high performance' wires are made of. I always use the inexpensive copper stuff, reliable and connects solidly with the 'set-screw' dizzy cap in the TR3s & 4s. A universal 8 cylinder kit is enough to make about 4 sets for the 4-cylinder TRs. Lousy for radio reception but great for ignition.
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
KiwiStagguy For Sale Stag Black Mohair New top Cheap Triumph Classifieds 0
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
L For Sale 1964 Austin FX4 Black Cab Other British Classifieds 0
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
HealeyRick Just in Time for Black Friday Austin Healey 0
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
steveg Conclave Deadwood 2019 - Black Hills Maps Austin Healey 2
D TR6 1976 TR6 Black Painted Parts Triumph 2
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
JPSmit DeWalt or Black and Decker or DeWalt or ???? Restoration & Tools 4
mrv8q TR2/3/3A Califiornia Black Plate Syncronicity Triumph 1
Rhodyspit75 TR2/3/3A Speed is the new black. TR3 Triumph 5
AngliaGT Black Lightning Motorcycle Cafe British Motorbikes 2
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
AH67 General TR Touch up Paint 11/PAA Black Triumph 2
Zitch For Sale FS- Brand new Black TR4 Deluxe Carpet Kit Triumph Classifieds 2
Jim_Gruber New Tiew Rod Ends. Paint Black Y/N Spridgets 5
Jim_Gruber Paint Color - Black Satin or Black Glossy for Suspension components Spridgets 9
Csarneson BP Northwest Black Friday Sale Austin Healey 0
Jim_Gruber BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale Spridgets 10
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
S TR2/3/3A black epoxy primer Triumph 1
G Black Box Spridgets 4
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
Sopwith_Camel the black wire or the black wire or the black wire or the black wire Jaguar 3
M TR4/4A Carpet....Black or Charcoal Grey? Triumph 9
paul9999 London Black Cab Other British Cars 18
Martinld123 Small Puff of Black Smoke When I Blip Throttle Austin Healey 6
T TR6 Black sooty plugs continue - What now? Triumph 29
tahoe healey tire black Austin Healey 13
B Replacement of Small Black Wire inside Distributor Austin Healey 15
R TR4/4A What color black paint in hte interior Triumph 1
Got_All_4 TR2/3/3A Gloss black or satin black paint Triumph 17
R BN6 Brake Drums, Black or Aluminum/Silver? Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
AH100M Why weren't sill and wing flanges painted black on BN1s and BN2s? Austin Healey 12
jollyroger Black seat kits for 62 sprite/midget Spridgets 6
R removing black seam sealing Austin Healey 3
DerekJ Primrose Yellow / Black with yellow upholstery Austin Healey 18
T black snaps for convertible top Triumph 11
Hap Waldrop Acme Speed Shop VTO wheel Black Friday Sale 20% off Racing 0
