BJ8 w/o brake booster?
WALTER
Why would my friends '66' BJ8 not have a brake booster. I looks like it never had one. And it is a beautifully restored Healey. Boosters were supposed to be stock from '63' on.
Walter
Ed_K
Walter,
On my 65, the original brake booster was long ago replaced and
also relocated to the other side of the engine compartment from the stock location. If you didn't know were to look for it, you would think I didn't have one either. Look to see if the vacuum hose is attached to the intake and then follow the hose if it is there.
Ed
WALTER
WALTER
Thanks Ed,
But not this one. Vacuum port plugged. Nothing but studs left at the foot well. Must not have been in the restoration budget.
W
Keoke
Me thinks you are about right. However, you might tell your friend there is a new PBR unit with brackets on E-bay now for $350.00 its a bargain and better than the original. Additionally, it is required to stop the big healey at speed.---Keoke
WALTER
WALTER
Thanks, I'll pass that on.
W
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
Marvin Gruber BJ8 brake booster Austin Healey 6
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Marvin Gruber BJ8 brake booster picture Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
P BJ8 Brake Booster mount Austin Healey 9
J BJ8 Brake Booster Austin Healey 5
LAW75 BJ8 Brake Lines Austin Healey 2
D BJ8 brake master cylinder question Austin Healey 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
wangdango BJ8 brake reservoir? Austin Healey 7
H BJ8 Exhaust System and Brake Servo Austin Healey 16
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
Marvin Gruber BJ8 brake connectors Austin Healey 17
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
J Emergnecy Brake Cable Replacement BJ8 Austin Healey 4
P Brake boost repair, BJ8 Austin Healey 10
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
R BJ8 with servo...Brake travel issue Austin Healey 30
R BJ8 Brake Drum Removal Austin Healey 6
C question on the front brake lines for BJ8 Austin Healey 2
L BJ8 Brake servo Austin Healey 6
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
T Soft brake pedal on BJ8 Austin Healey 3
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
S BJ8 rear brake drums Austin Healey 8
letemglow Brake master cylinder BJ8 Austin Healey 0
healeyneil Sticking back brake BJ8 Austin Healey 0
J BJ8 brake light not working? Austin Healey 2
C BJ8 brake fluid disappearing Austin Healey 11
C BJ8 brake servo options Austin Healey 5
J Late BJ8 brake rotor- thickness specs Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
C AH3000 BJ8 Brake Caliper question Austin Healey 7
R 67 BJ8 Brake Light Switch Austin Healey 2
R 67 BJ8 Brake Fluid Resivor Austin Healey 6
R BJ8 brake calipers Austin Healey 14
S BJ8 Emergency Brake Lever Loose Austin Healey 1
D brake light problem 67 BJ8 Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
