Best Spark Plugs for BJ8
CJP
What would be the best spark plugs for me? I have a 1967 Austin-Healey 3000 Mark III, negative ground. I just order a PerTronix Ignitor, coil and rotor from Classic Garage. I have a radio. Thanks, Curt
I've always been happy with NGK BP6ES (maybe you'd want BPR6ES for the radio suppression).
The Champions never seemed to *clean* themselves off after a period of idling, like stop & go traffic.
I recommend staying away from any of the hyped Platinum, Iridium, or younameitium. You just don't see the benefits in our cars, and may not last as long as plain old NGKs.
I like the NGKs and have been using them in British cars something just over thirty-six (>36) years. They're even fitted from the factory in my ///M Rdstrs.
C
CJP
Thanks, Randy that was the plug I was thinking about going with! You made it easy. I just ordered 6 on Ebay for 1.69 ea. Now what would be the best wires to go with my setup. Thanks again Curt
I don't know, I make my own; no radio, so I use real wire! Moss catalogs a premium aftermarket set, and I think they're supression type...
CJP said:
... what would be the best wires to go with my setup ...
If you're using a stock type distributor cap with the screw-in terminals use stock (or 'bumble-bee' striped) 7mm copper stranded wire. If you use 'modern,' wire-wound/silicone wire you'll develop a miss sooner or later.
As suggested, resistor plugs and/or resistor plug terminals will help suppress radio noise.
HealeyRick
Bumble bee wire is solid core copper wire and will generally give lots of radio noise. I'm not sure even resistor plugs would quiet it.
Genos2
Bosch style wire ends are available in several ohm ratings from 2-5.5, Audi,VW&BMW use them, w/solid core wire, no static. Genos2
C
CJP
Has anyone had a problem with the radio noise using Bumble bee wire. If so what did you do? -- Thanks Curt
C
CJP
Our these the caps to get? Thanks Curt
Click Image to Enlarge Ign Wire Connector
Brand: Bosch
Part # W0133-1636202
Product Weight: 0.06 lb
Minimum Order Quantity: 1
Leaves Warehouse: by Midnight Tuesday
MSRP: $14.96 Your Price: $7.15
CJP what image do we click on? My experience with the plug caps I got from Moss is that they don't snap on tight to make a good connection. Jeff at Advanced Distributor made me a set of new wires with his connectors that really have a firm contact. He had to put them on the wires with a special tool.
My local Advance Auto Parts store does not have NGK BP6ES plugs, only BPR6EY- would those work? $4 each.
Keoke
Whatever unsuppressed plug you choose go with Bosch plug ends.
this will ensure that unsuppressed plug wire will not cause you a noise problem
red57
Do an internet search for "BP6ES" They are available from Amazon, NAPA, Walmart, eBay, Summit Racing, Grainger, and lots of other suppliers. They are what I've always used and never had trouble finding them.
Supposedly, some of the Japanese brands--esp. NGK--are being counterfeited by you-know-who. The upside of running Champions is I doubt anybody would bother counterfeiting them. FWIW, Champion is the go-to brand for aircraft piston engines (both massive electrode and fine-wire).
If your plugs are fouling you might have the wrong heat range (and/or you're burning oil). Champion RN12YC have served me well for decades (I bought a bunch at Pep Boys for $1ea a few years ago). IIRC, they have about 15KOhm resistance.
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
K Best spark plug wires with Pertonix:what to use? Racing 1
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
