BJ8 Smoothline top value
Chris_Masucci
Hi Folks,
Can someone give me an idea as to roughly what one of these tops is worth? It's in nice shape but will need new seals, paint and headliner.
Cheers,
Chris
Patrick67BJ8
Chris_Masucci said:
Hi Folks,
Cheers,
Chris
There;s two different Tops from the company. The original Parrish and the Smoothline. Post pics. Rubber seals are available for both.
HealeyRick
You can get a brand new one unpainted for $1200 https://www.smoothline.com/austin_healey.php Maybe you can figure the value of the one you're interested in down from there. They don't command the values that the factory BJ8 tops do, but I understand they can be mounted without removing the entire convertible top mechanism. Aesthetically, they just don't do much for me but YMMV.
Jeepster
I was initially very tempted by the Smoothline top at $1200 ( they do international shipping) until I took a closer look at the rear window. Its just not the same as the large factory version, just doesnt look right.
Repro tops over here are £2000 for a basic version, far more than I can afford and second hand ones dont come up very often, if they do they are usually the same kind of cost.
Are there any other US companies that do repro tops that look more like the originals?
Jeepster
And another thing ? ? ?
why is a repro hard top for a big Healey over £2000 / $3000 plus lots of extras and work to fit, when I can buy a repro hardtop for a sprite for less than £400!
I know they are a slightly different size but I fear they are being priced to the market rather than manufacturing costs etc. I could make the same point about wheels too.
Johnny
I've seen one that fit a two seater also. Not as good as the original of course.
Patrick67BJ8
Factory style Hardtops for the BJ7&8's must be fitted to each individual car because each car is different. There was approximately 300 of these Tops made.
Aftermarkets do not have to be fitted because the sit beyond the rear curved chrome trim piece. These Factory tops for BJ7&8's were made by the Donald Healey Motor Co and not BMC like the earlier Tops. You'll notice that the earlier Tops fit differently where they touch the cars body.
66healey
Member
The tops not worth much. I basically couldn't give mine away. Also because of how it rides on the rear shroud, it will tear up the paint on the rear shroud. I have decided that I will use mine to practice painting on before I get to the rest of the car, and then just leave it hanging in the garage.
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
