• Dear Guest!
    If BCF is a useful resource for you, if you appreciate not having Ads pop up all the time, and if you want to ensure we can stay online -
    Please consider supporting us by **Upgrading**
BJ8 door trim
The chrome on the door seemed to be loose so I pulled it off. The PO held it in place with some kind of putty. Not a problem since I hadn't noticed it for years. But it seems a little too Mickey Mouse. How is it suppose to be held on? It slips on and seems to click in place but moves easily with out the putty.
Thanks.
Dave Russell
Yoda - R.I.P
Rich,
I think that the door top moldings are held on with clips such as moss #326-175. The same type of clip is used to hold some of the weatherstrip. Maybe the PO didn't want to spend $.40 each for the clips. If you do have the clips maybe they are bent & need to be replaced.
Stretch
It's been a while since I had this apart. As I recall there are approx five spring clips that hold the outer weather strip to the chrome. The clip is shaped to fold back over itself so that the other half can slip over the top lip of the door. The clips have teeth that bite into the door lip to hold the chrome in place. A rope caulk strip goes between the back of the chrome and door. At the front a small screw goes through the chrome and door from the inside under the door panel.
John Loftus
Stretch is correct except there are 7 clips (I'm not relying on memory ... the trim is sitting here in the office) ... you can see the exact placement for the clips if you look at the rubber wiper/weather strip for the glass. The square detent areas on the rubber are the locations used for the clips. And thanks for the comment about the rope chaulk ... mine is long gone and will remember to add some during installation.
Cheers,
John
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
LAW75 BJ8 Door Locks Austin Healey 2
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
wangdango BJ8 door hinge milling? Austin Healey 2
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
B BJ8 Door hinges Austin Healey 16
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
T BJ8 door glass replacement Austin Healey 4
B BJ8 door seal attachement point. Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
M Bj8 door disassembly Austin Healey 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
Editor_Reid BJ8 Door Glass Austin Healey 6
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
B Need a SS Exhaust System complete, for BJ8 1967 Austin Healey 4
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 2
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 4
