• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
Bj8 door disassembly
Martec
Member
Hi
This is my first message on here. I am starting the resoration of BJ8 and presently am dismantling the door as it requires repairing. I have removed the quarter glass and the screws at the bottom of the window track inside the door. I still cant get the quarter glass frame/front window track out of the door. Are there other fasteners to remove? Any ideas would be appreciated.
Thanks
Mark
AUSMHLY
Hi Mark,
Welcome to the forum.
Remove the outside chrome door waist moulding.
Remove both the inner and outer weather strips.
Remove the door stop glass bracket
Remove the door glass. Pull straight up.
You may see two small screws (on the outside of the door) where the waist moulding was. They screw into the vent window frame. Remove them.
Remove the two screws on the inside top of the door that screw into the vent window frame.
Remove the two screws on the bottom of the vent window frame.
6 screws hold the window assembly to the door.
Now you should be able to pull the entire vent window assembly straight up.
Good luck,
Roger
M
Martec
Member
Hi
Thanks for the reply. I have only to get the 2 screws on the outside of the frame and the job is done. They seem stuck and wont un-screw. Any Ideas?
Cheers
Mark
Cutlass
Not un-importatant to the restoration of these cars is the art of removing rusted, stuck or broken fasteners. First, try soaking in penetrant as recommended. When that doesn't work, as it most often doesn't, other options are drilling, grinding, swearing, heating, swearing, and oh, did I mention swearing? Oh, I forgot, you can try drilling then breaking off an easy-out, then repeating the above. Seriously, though, these are small screws, and if you have already ruined the heads, go ahead and drill them out.
AUSMHLY
Cutlass is such the optimist. When that doesn't work....
On the other hand, Cutlass is right! Been there and done that.
Oh and the swearing aka cussing...it helps.
Good luck,
Roger
M
Martec
Member
Great help thanks! The algorithm in a nutshell.
1 Lots of pentrating oil and then try to loosen
2 If they wont loosen them some swearing and throwing of tools. ( keep some cheap ones near by so you dont wreck an expensive torque wrench or similar oh and dont throw them at the car no matter how tempting it is to do so).
3 More oil and leave soak overnight!
4 Try to loosen them
If screws loosen tidy up thrown tools etc and have a few beers!!
else goto 2
It worked for me but it took a few days af trying at various times. The screws came out ok so now the door is apart and ready for repairs. Ill order the repair panels from Kilmartins today.
Cheers
Mark
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 9
LAW75 BJ8 Door Locks Austin Healey 2
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
wangdango BJ8 door hinge milling? Austin Healey 2
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
B BJ8 Door hinges Austin Healey 16
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
T BJ8 door glass replacement Austin Healey 4
B BJ8 door seal attachement point. Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
Editor_Reid BJ8 Door Glass Austin Healey 6
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
tahoe healey BJ8 door trim Austin Healey 3
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
AUSMHLY BJ8 Mainshaft Needle Rollers, 32 or 33? Austin Healey 6
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 1
AUSMHLY BJ8 selector shafts and forks condition Austin Healey 2
LAW75 BJ8 Directional Indicators Austin Healey 4
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
W BJ8 Transmission Installation Austin Healey 0
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
