bob hughes
Hi guys
Had to replace the rubber to the channels forming the L shape around the side glass. I found it very difficult to get the glass in to the correct position, even after knocking 7 bells out of the glass with a rubber hammer, I had to split the frame on the second one as the rivets were shot. this gave me an idea to put each part of the frame on seperately then rivet up after. Must have done something wrong as it all unravelled after installing it back into the door. I have now resorted to using silicone and we will see how that goes. The obvious down side is having to remove the glass at a later date, but during trials I was able to get a thin knife down between frame and glass to cut away the silicone. Any one else tried this method.?
Bob
Bob
