Best air cleaners/ filters for street
Slick Willy
I have started looking at air cleaner and filters. I would like your input and wisdom on the matter. In the VB catalog I have been looking at the K&N part #3-1802, filter #3-1811, or the flat chrome #9-103. I would like to know real world and first hand from you guys. Are they worth the money or what do you recommend. I have stock as of now, which seem to be alittle restrictive to me. I plan on a set of headers, new exhaust and a harley muffler upgrade. I will say I am a sucker for chrome. I come from a Harley and hotrod back ground. So please, any input would be great, thanks.
S
Slick Willy
Those look great Trevor. I really dig the script, you have a gift sir. What would a set of those cost? Do they use stock filters?
Thanks, but it requires not talent ... they were made by machine. They are essentially 1/4" aluminium plates that sandwich filters that have the stock diameters. There are about 3-4 filters of different heights that work. I was making them with a home built CNC mill. I'd let it run while I was out in the garage working on other jobs. But the constant noise was irritating and I quit making them.
You could do something similar using the stock base, and some 1/4" aluminium. If you wanted to dress it up a bit, then a sign shop could make a vinyl decal.
S
Slick Willy
Thanks for the tip. They still look killer no matter how you made them. I've been looking at the chrome pancake stlye, I think they are 1.5 inch. I really like they look. I have started degreasing the motor so I can paint it. Thanks for the input and help.
Pythias
if you put stub stacks inside the filters you WILL notice a difference in power. .. I don't know the exact ones anymore, but aptfast.com has the K&N filters and the stacks. ..
There is a hill on one of my runs nearby. With the old engine and stock filters/cans, I had to downshift to 3rd to make it up the hill. the next day, with stacks and K&Ns, (the 3 inch high ones) I could accelerate up the hill in 4th..... noticeable.
So Bill, do you think it increased the max hp of the engine or just widened the range that the HP was available.
S
Slick Willy
I am no expert on British cars or motors. I have seen better out put on Harley's and My old 392 Hemi with daul 4's by using free flowing exhaust and air filters. I dont feel it added more hp just gave it quicker and over a wider range. I'm going to give it a try and see what happens. Here in the mountains of eastern Kentucky a little more power is always a good thing. I have yet to adjust the carbs. As the car came to us from Florida it would probably benefit from some tuning. Thanks for the help guy's.
Pythias
It felt stronger across the whole rpm range.... and fuel economy seemed to go up.
K Best air filters? MG 7
G 1960 TR3A for sale $9,999 or best offer! Triumph Classifieds 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
Popeye TR4/4A Best way to transport a bare tub? U-haul utility trailer? Triumph 11
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Best head gasket for a 4A? Triumph 12
C Best source for Lemans Kit, including bonnet Austin Healey 5
steveg Best Fire Extinguisher Location Austin Healey 38
T 'best' fan blade configuration? Spridgets 2
S Best Top Down Tune Spridgets 36
fpstude TR2/3/3A British Car Owners are the BEST! Triumph 4
C TR4/4A Best way to remove transmission fill port? Triumph 8
N Best Carpets? Spridgets 5
T Best Shop Manual for BE Spridgets 9
H 1953 Pebble Beach Best of Show Austin Healey 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
Rut Best interior supplier Spridgets 28
