Before and after Pics of My Frame and a Video
Miser
Before
After
Video
https://www.youtube.com/watch?v=MhpGlUTNKX0
M_Pied_Lourd
A thing of beauty.
Cheers,
Tush
PeterK
I prefer the satin finish on your frame (used it on my frame too but mine is not PC'd).
Saw on your video that you stated it should not rust again but keep in mind that they rust from the inside out so be sure to get the inside coated with waxoyl or similar. I used an Eastwood rustproofing sprayed inside the frame. I bet that undercoating was a pain to remove.
Very nice starting point.
Brosky
See how nice all of those oil leaks preserved the outside of that frame for you? Factory exterior waxoyl by British Leyland.
Jerry
I watched your video, How did you get the frame back to bare metal? grinding, sanding, dipping or blasting?
Jerry
simpson
Very, very nice. Looks like you started off with a great condition frame. Couldn't see in the video, but did/are you boxing in the differential support pins?
M
Miser
I have all the differential support system apart and I am restoring them, if that is what you mean
justin_mercier
The differential support pins on the IRS Triumph frames are notoriously bad and tend to crack and rip out of the frame. This can be prevented by boxing in the supports (i.e. welding sides onto the cross-members) to prevent them from flexing and failing.
M
Miser
Oh yes I am installing a super charger so I will be doing that
simpson
Miser, In the vid you rubbed one of the pins up and down like. I know you might hate to mess up the finish in those 4 areas now, but no better time to do it with such good access, and before they get damaged. Reinforcing them as Justin described above not only gives peace of mind, but if ever in the future you modify the engine for more hp or performance, your differental mounts will be up to the task. Solid investment all around - great selling feature too if that ever happens.
M
Miser
OK I will do that now. Is there somewhere on the internet that walks me thru the process?
HerronScott
Very nice looking! How much does it cost to powdercoat a whole frame?
Scott
bgbassplyr
You will want to run a tap or die on all of the threads as powder coating will add material in those areas that will make it hard to install nuts and bolts.
Clean them up and then, perhaps, add a light coating of rust encapsulator.
The frame looks GREAT!
M
Miser
Scott
They charged me $1200 but that included many parts including the wheels and convertible top that will be delivered to me on Tuesday. Also I did order the kit to reinforce the differential bolts from Moss.
simpson
Do search over on 6-Pack. Probably alot of guys have documented or talked of this modification over the years.
tdskip
Have done this 3x now on the two TR6 and TR4a and am local if you want some coaching on it. Much easier to do now unless you are looking to experience hot weld fragments dropping on your face. Expect some minor trimming on the Moss kit. I ended up just making mine reinforcements from thicker stock on the two later cars.
Also, and the guys said get some coating inside the frame before putting her back together.
Now I'd also the time to reinforce the front gussets if that hasn't been done. Also much easier with the frame off.
B Before and After Pics Longbridge 100-6 Austin Healey 5
G HBT7L/18762 - Pics before Preservation Austin Healey 15
pjsmetana Some recent Before/After pics :] Triumph 8
regularman Father in law found some pics of the midget before Spridgets 4
6 trying to post before pics Triumph 6
G Before and after pics of an Ebay LBC Restoration & Tools 24
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
DrEntropy Before they were Vintage Racing 0
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
D General TR Fuel filter before the pump. Triumph 2
JPSmit Hagerty Prediction - Cars to buy now [before they get expensive] Spridgets 1
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
P T-Series MGTD - before and after MG 3
D TR2/3/3A Excessive cranking before it starts. Triumph 47
D Prepping Floors Before Installing Interior Restoration & Tools 6
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
J Wedge TR8 research before purchase Triumph 16
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
simon1966 Before and After Austin Healey 2
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
C Static timing before engine start up Spridgets 4
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
R Last minute check before engine install Austin Healey 26
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
jlaird Before I put in classifieds Spridgets 36
RickB Questions before seeing insurance appraiser Spridgets 12
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
B Spitfire before i swap this od transmission into my mk3 what would you do? Triumph 11
DNK Never Seen One of These Before Other British Cars 3
hilsideser Never seen one of these before... Spotted 5
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
apbos What can I bolt to the engine before I install it? Spridgets 12
DerekJ Ever seen wire wheels like this before? Austin Healey 5
Lukens TR2/3/3A Think I'll add a fan on TR3 before I need it. Am I being overly cautious? Triumph 13
L Adjusting the bows before top installation Austin Healey 2
P Thanks Basil!! Spridgets before Sunbeam! Spridgets 1
F Somebody buy this owner's manual before I do Austin Healey 28
RickB Before and after top with 303 Aerospace protector Spridgets 8
bugedd Last chance before it becomes a planter Spridgets 11
JPSmit Before and Afters Restoration & Tools 4
bugedd Before I put it on ebay.... Spridgets 0
mrv8q The Night before Christmas Triumph 2
