I'm installing my hubs on a new Denis Welch Racing stub axle. All new Timken bearings. When I fit everything together with no shims and tighten the castle nut to 40 ft/lbs, I am unable to move the hub. If I tighten to about 20 ft/lbs the hub moves freely with no end float. I don't see any issues with the hubs and the bearing races are fully seated. Is it acceptable to install without shims and only the 20 ft/lbs as long as I can get the cotter pin installed or am I doing something really wrong here? I'm a little gun shy about destroying the new stub axle given the price of a new one.
Thanks in advance,
Thanks in advance,
