So we have taken in my mother's '71 MGB in which my grandfather has been holding on to. He ran it regularly, and always had it plugged into a trickle charger, etc, all maintenance done, that sort of thing
Now im back on college break. My parents never run the car. It probably hasnt been driven for about 3 weeks, and this problem occurs often during the winter months. What happens is that the charger says the battery is fully charged, then when u go to start it, it wont start. I used my battery box to jump start it, started right up. Once i get it running, i turn off the box, and then it will die approximately 15 seconds later. It will only run on the battery box, although it seems like the batteries can hold charge, just not very much. Im not sure if these are the original batteries or not, all i know is that there are two of them, lol.
Any suggestions? Also, would it be worth it to buy new batteries? Is it tricky to install batteries in a car that uses two?
Thanks in advance!
Thanks in advance!
