chicken
I am having problems fitting the grommet and cover plate in the battery panel in the boot, the one where the batt cable goes through.
On my battery panel (the piece that covers the fuel pipe filler) the hole that takes the grommet is bevelled therefore the grommet cannot simply push through and lap over the flat surface on the other side (as a normal grommet should)as the bevel on the other side prevents it.
The panel was a part i bought from AH Spares so i assume it is correct, so what am i doing wrong, i have the grommet and the trianglier plate to hold it in place but it's stumped me.
I'm also wondering the routing of the main wiring harness when it leaves the flasher relay.
Can anyone help.
Rob
Can anyone help.
Rob
Hi Guest!
